good Timing under boost?
Old Aug 25, 2004 | 01:40 PM
93TurboSi's Avatar
Default good Timing under boost??
I have a built d16z6 running the greddy turbo with an aem ems. I'Ve been tuning for 15psi and i have good afrs in boost 11.5 +/- .2 . the problem is i'm either getting misfires or detonation once past maybe 12- 13 psi up through 15psi. i wondering if my timing is bad. let me know if these timing numbers are good or if they are maybe to aggressive and advanced or maybe even i went to conservative and had to much retard. i'm running 9:1 compression on 93 octane pump gas.
these numbers are from 4500 - redline
15.4psi = 16.4
13psi = 18.9
10.7psi = 21.3
8.5 psi = 24.1
6.4 psi = 26.6
4psi = 29.1
2psi = 31.2
Modified by 93TurboSi at 4:32 PM 8/26/2004
Old Aug 25, 2004 | 02:07 PM
PTR1's Avatar
Default Re: good Timing under boost? (93TurboSi)
I wouldn't go below 19 deg. of total timing. Have you check your plugs, what are they gap at?
Old Aug 25, 2004 | 02:12 PM
*Boostwerks*'s Avatar
First of all...make sure your base timing is fine.
A properly setup engine running around 12:1afr should not be detonating around 16degrees timing. 16 degrees is pretty low, but its a perfect place to start.
read your plugs and make sure you are infact detonating.
Old Aug 25, 2004 | 03:56 PM
USDM 4G VTEC's Avatar
i am interested on this also
how many degrees do u guys consider optimal??
i know it varies from engine to engine, but theres usually a typical average
tought i would keep around 23 degrees on mine......
Old Aug 25, 2004 | 04:39 PM
Tchleung's Avatar
n00b question. when people ask, what timing was it at. what does that refer to? timing at max load at redline?
Old Aug 25, 2004 | 05:14 PM
93TurboSi's Avatar
Default Re: (Bryson)
well i went and confirmed my timing on the ems and found i was about 3 degrees retarded to begin with. so at 15 psi i was really at 13.4 degrees of timing. from what it sounds like here that is really really retarded. Could being that retarded cause a small backfire. because the noise i heard sounded like it came from my exhaust like a low toned pop from my muffler.
so what kinda timing would be a good place to start with 15psi (yes i know every engine is different i just want a good conservative starting point.
would 19-20 at 15 psi be good
Old Aug 25, 2004 | 05:45 PM
93TurboSi's Avatar
Default Re: (93TurboSi)
here are my new timing numbers. I haven't driven on them yet but let me know what you think. Also the timing is now synced very well.
again these are from 4500-redline with 11.5 =/- .2 afr 9:1 compression on 93 octane:
17.54psi = 16.8
15.39psi = 18.9
13.04psi = 21
10.70psi = 23.1
8.55psi = 24.8
6.40psi = 26.9
4.06psi = 29.1
1.91psi = 30.8
0psi = 32.6
is it looking good?
Old Aug 25, 2004 | 05:53 PM
Freemantle's Avatar
You are compensating for engine speed.... right? Not just running:
17.54psi + 6000rpm = 16.8 deg advance
17.54psi + 5500rpm = 16.8 deg advance
17.54psi + 5000rpm = 16.8 deg advance
17.54psi + 4500rpm = 16.8 deg advance
17.54psi + 4000rpm = 16.8 deg advance
Old Aug 25, 2004 | 06:43 PM
93TurboSi's Avatar
Default Re: (Freemantle)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Freemantle &raquo;</TD></TR><TR><TD CLASS="quote">You are compensating for engine speed.... right? Not just running:
17.54psi + 4000rpm = 16.8 deg advance</TD></TR></TABLE>
well i'm basing it off the base aem startup maps and other peoples maps and they all have timing in the same load row go flat from about 4500-5000 to redline
so for example in load row 15.39psi at 500rpm timing is 1.28 and ramps up quickly to 18.5 by 4100rpm then timing is 18.9 from 4500 - 8500 (my redline is at 7600)
all the boosted aem timing tables i have seen go flat like this and have all the same timing through out the load row from about -4500-5000 up.
actually here is a screen shot of the timing table and graph:
does it look all right. all the other aemmaps look similar
Modified by 93TurboSi at 4:07 AM 8/27/2004
Old Aug 26, 2004 | 05:41 AM
93TurboSi's Avatar
can some one take a look at my timing table and see if it looks decent. any suggestions would be great.
Modified by 93TurboSi at 3:48 PM 8/26/2004
Old Aug 26, 2004 | 07:34 AM
93TurboSi's Avatar
bump
Old Aug 26, 2004 | 12:02 PM
Default Re: (Tchleung)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tchleung &raquo;</TD></TR><TR><TD CLASS="quote">n00b question. when people ask, what timing was it at. what does that refer to? timing at max load at redline?</TD></TR></TABLE>
Normally, they are just refering to the what the computer advances the timing too. Most will just keep the mechanical base timing stock.
The actual value we are refering too is the Max. timing under full boost.
The amount of timing the engine should need is based on a whole bunch of factors, which is why its just best to dyno tune the car to find the sweet spot. Everything from compression to cams is going to effect how much timing the motor will need.
20 degrees is probubly the maximum amount of timing I would run on a pump gas motor with a decent amount of boost. Personally, I would rather have it conservatve than on the edge so I would keep it around 18.
Old Aug 26, 2004 | 12:04 PM
Tchleung's Avatar
ahh. gotcha. thx!
93TurboSi
Aug 28, 2004 06:57 PM
wzcb08
May 19, 2003 07:47 PM
deacs
Oct 11, 2002 09:33 AM
hybrid901
Sep 11, 2002 05:33 PM
LudeSi-93
Jun 21, 2001 07:46 PM
