Vortech supercharged Type R Problems help
Old Aug 28, 2004 | 05:47 PM
98-0688's Avatar
Default Vortech supercharged Type R Problems help
98 type r
mods are
rc 310 injectors
vortech FMU
aem Fuel pressure Regulator
vafc2 controller
3inch Thermal exhaust
test pipe
jdm 4-1 header
msd 6al BTM
also the fan in the supercharger turns a little bit. is that a problem or is it supposed to do it?
i have no fuel pump
no air filter
no oil cooler air cooler.
i have the power cooler and a dump tube going to the oil pan
as soon as vtec engages it backfires and shoots a flame out. i can only do about 30% throttle without it bogging out and backfiring.
what could be the problem with the car?
Old Aug 28, 2004 | 06:34 PM
m R g S r's Avatar
Default Re: Vortech supercharged Type R Problems help (98-0688)
Plug gap?
Old Aug 28, 2004 | 06:37 PM
t04ecvc's Avatar
Check that the VAFC2 is setup correctly, sounds like it might not be setup right. Could also be your map sensor, is there a CEL on?
Old Aug 28, 2004 | 07:09 PM
98-0688's Avatar
Default Re: Vortech supercharged Type R Problems help (t04ecvc)
stock setting with plugs
the cel is on.
Old Aug 28, 2004 | 07:49 PM
twkdCD595's Avatar
by chance do you know what codes it is throwing?
Old Aug 28, 2004 | 08:40 PM
98-0688's Avatar
Default Re: Vortech supercharged Type R Problems help (twkdCD595)
something with the oil
Aug 30, 2004 01:28 PM
Downs
Apr 13, 2004 03:20 PM
greengangsta
Jun 7, 2002 02:06 PM
