turbo spools but no boost.
Old Aug 28, 2004 | 03:04 PM
johnsona's Avatar
Default turbo spools but no boost.
turbo spools but no boost. I checked all the the stuff from intake to throttle body and cant find a thing and still dont know what it is please someone help because its killing me i just wanted to see if anyone had any ideas that i havent thought of or something that i might of missed over. thanks all for your imput
Old Aug 28, 2004 | 03:05 PM
93turbo16's Avatar
It would either be an intercooler pipe that blew off or your wastegate is stuck open.
Old Aug 28, 2004 | 03:10 PM
SSBPGSR's Avatar
Default Re: (93turbo16)
what he said ^^, check your wastegate, maybe your bov is leaking??
Old Aug 28, 2004 | 04:10 PM
Ace.'s Avatar
Default Re: (SSBPGSR)
I had a similar situation with my car about a week ago....ended up that my turbo wasn't getting any oil, smoked the bearings down on the inside, which created super slop shaft play...
The above are Both are good ways to start, but also do what I did: Take of the intake and check for shaft play...you may have had lack of oil to your turbo and in turn cooked your turbo...
Old Aug 28, 2004 | 06:19 PM
brixity's Avatar
is it possible that you are running lean. what fuel setup do u have? mine is leaning out and its not boosting all the way like its supposed to.
Old Aug 28, 2004 | 06:28 PM
m R g S r's Avatar
Default Re: (brixity)
Sorry, but running lean will not cause the car to not see any boost.
Old Aug 28, 2004 | 06:32 PM
Freemantle's Avatar
Default stuff
Are you sure it is really spooling? Are you sure it isn't just spinning a little bit? If you can't find any leaks or major exhaust restrictions you should check to make sure all of your cylinders are firing.
Old May 9, 2006 | 12:44 AM
em1 Ziggy's Avatar
Default Re: stuff (Freemantle)
BUMP!
Old May 9, 2006 | 08:04 AM
yee SERIOUS's Avatar
my wg got stuck open once. no boost until i pulled it into boost and then it finally closed.
MiMiK
Dec 10, 2005 06:21 PM
j-robsDA
Jul 11, 2004 08:29 AM
JonGP4
Jan 4, 2004 09:30 PM
jdmtegxsi
Jan 23, 2003 08:23 PM
Cyber ITR
Dec 9, 2001 01:51 AM
