12.3@119mph Help pls!
Old Aug 25, 2004 | 02:57 PM
freakie's Avatar
Default 12.3@119mph Help pls!
whats wrong with my setup or what am I doing wrong?
119mph is good enough for a low 11 second pass isnt it?
any help much appreciated. 60 ft was 2.1
Old Aug 25, 2004 | 03:23 PM
86si's Avatar
Default Re: 12.3@119mph Help pls! (freakie)
This sounds like a topic for drag forum but anyway more like high 11s 11.7or11.8
Old Aug 25, 2004 | 03:24 PM
Boostage's Avatar
actually 119mph is high 11'sor low 12's. low 11's is 126-130mph
Old Aug 25, 2004 | 03:30 PM
Mikes01GSR's Avatar
Default Re: 12.3@119mph Help pls! (Boostage)
Hell don't feel bad I did 12.6 @ 120.7, traction is a bitch.
Old Aug 25, 2004 | 03:33 PM
buda18's Avatar
Default Re: 12.3@119mph Help pls! (Mikes01GSR)
yeah man just gota practice more and get those launches down. 1.8 60fts help a lot too.
Old Aug 25, 2004 | 03:38 PM
stizzit's Avatar
haha try 13.3@118mph, thats what a HUGE turbo will do for you, slow off the line and then no traction lol, like two extreme's.
Old Aug 25, 2004 | 03:43 PM
sittin on GOLD's Avatar
Default Re: 12.3@119mph Help pls! (stizzit)
RT .0721
60 2.072
330 5.291
1/8 7.693
MPH 106.49
1000 9.678
1/4 11.381
MPH 134.24
NO wheelie bars
fully gutted
24.5x9x13 on MT
Old Aug 25, 2004 | 03:51 PM
USDM 4G VTEC's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by freakie &raquo;</TD></TR><TR><TD CLASS="quote">whats wrong with my setup or what am I doing wrong?
any help much appreciated. 60 ft was 2.1</TD></TR></TABLE>
either learn how to drive
or get some better slicks
with at least dropping the 60' down to 1.6 or 1.7, it will run 11.7-11.8
Old Aug 25, 2004 | 10:52 PM
Kwuaymaikrup's Avatar
That is not too bad. I went 12.01@118 my first time out. My 60' was like 2.2 or something. More seat time will get you numbers you are looking for. What slicks were you on and what kind of power are you making?
Old Aug 25, 2004 | 10:55 PM
shermanyang's Avatar
Default Re: 12.3@119mph Help pls! (Kwuaymaikrup)
LOL, i've done worse....13.5 @ 119mph little 14x20x7 slicks and missing 5th gear everytime will cause this
Old Aug 26, 2004 | 06:12 AM
b00sted2.0L's Avatar
that is not to bad. i ran a 12.5 @118 while back. then recently went 11.7@124 with a 1.9 60ft.
Old Aug 26, 2004 | 06:36 AM
Squirtle's Avatar
Default Re: 12.3@119mph Help pls! (b00sted2.0L)
What did you change?
Old Aug 26, 2004 | 08:37 AM
scartail's Avatar
if u slow down after the launch.. then sped up... u can have a high et and a high speed... i was puzzled by the same thing.. did two runs.. one had a lower et, but a slower speed... the other showed a higher et, and a higher speed...
Old Aug 26, 2004 | 10:01 AM
DIRep972's Avatar
Smarter than you
119 could go low 11's if u get outta the hole.. Would need to leave w/ a low 1.6 60' and cut prolly a 4.6 330' but it can be done. Most people go high 11's w/ 119 though. Work on that 60'. how much air pressure in the slicks. what size are they? are they new or old? did u do a burn out? what gear? how much boost off the line?
Old Aug 27, 2004 | 06:51 AM
SVPxJERRY's Avatar
Default Re: 12.3@119mph Help pls! (DIRep972)
I went 11.0@121mph in a street car 1.7 60ft.
Old Aug 27, 2004 | 07:20 AM
stizzit's Avatar
Default Re: 12.3@119mph Help pls! (DnRperformanceSvP)
sickness, i need an LSD, some stage 9million axles, and some 26" slicks, then ima give it hell!
10's here i come (from 13's haha)
Old Aug 27, 2004 | 08:03 AM
Mikes01GSR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DnRperformanceSvP &raquo;</TD></TR><TR><TD CLASS="quote">I went 11.0@121mph in a street car 1.7 60ft.
What kind of car was this? I would imagine it would have to be pretty lite.
Old Aug 27, 2004 | 08:38 AM
turbo*s2k's Avatar
Get the 60ft. down to 1.7-1.8 and you'll run 11's! Was that on slicks? Looks like maybe drag radials...
hondaracer13
May 1, 2008 10:55 AM
vaporboy12
Mar 9, 2007 06:44 PM
b16ahybrid
Apr 19, 2004 07:29 AM
1320ForLife
Sep 15, 2003 10:21 AM
ALLMOTOR18
Aug 2, 2003 11:30 PM
