boost question
Old Aug 25, 2004 | 11:38 PM
b00sted_GS-R's Avatar
Default boost question
I am currently boosting 10 psi with the pos hack. Just bought a hondata want to boost 15 psi is that safe with my setup?
b18c1
walboro 255 intank
eagle rod
srp piston 9:8 comp.
rc 440 injectors
kms block guard
jg intake manifold
magnacore wires
soon 3 bar map sensor.
and losing the FMU
Old Aug 25, 2004 | 11:40 PM
99blackcivicSi's Avatar
Default Re: boost question (b00sted_GS-R)
i don't forsee a problem, just make sure you arn't running out of fuel on the high end with the 440's. also ditch those magnacore wires and get some stockies or NGK's
Old Aug 26, 2004 | 11:17 PM
any ideas what whp i should be making at 15 psi with 93 pump?
Old Aug 26, 2004 | 11:19 PM
vaporboy12's Avatar
dont go for psi goals go for whp goals
id say 440's will max a bit below 300whp
Old Aug 27, 2004 | 01:13 AM
Default Re: boost question (vaporboy12)
Im putting down 280 whp with the hack at 10 psi. and i had alot of room to play with on the injectors..
imskatencrzy
Mar 22, 2007 07:10 PM
1sikhatch
Nov 12, 2005 02:50 AM
mitchellP
Oct 7, 2005 06:47 PM
shervin
Apr 16, 2005 07:16 PM
Hybridhonda10
Mar 30, 2002 03:08 AM
