stock gsr axles... how much power can they take?
iv got stock 98 gsr axles in my 97 civic. wondering how much power people have been pushing generally before they break. thanks.
Re: stock gsr axles... how much power can they take? (lanojp1)
like everyone said, stock power could break one but most seem to start snapping them around the 300 whp mark, I'm around 280 whp right now, with gsr axles, If I get slicks, I'm sure I'll break on sooner or later.
Re: stock gsr axles... how much power can they take? (mike1114)
hmm interesting. iv never really researched replacement axles. What are some good replacement (without going overboard). that can handle around 300-400whp.
Re: stock gsr axles... how much power can they take? (donkiman)
433 WHP on pump gas, and my street tires are 225/50/15 BFG drag radials. I drive this car HARD, and have put over 15 thousand miles on it at 433 WHP. Only axles ive broke are at the strip, I snapped 2 while I was running 24.5/8.5/15 slicks with a LOT more boost than when I made 433 WHP.
Re: stock gsr axles... how much power can they take? (boosted92)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boosted92 »</TD></TR><TR><TD CLASS="quote">433 WHP on pump gas, and my street tires are 225/50/15 BFG drag radials. I drive this car HARD, and have put over 15 thousand miles on it at 433 WHP. Only axles ive broke are at the strip, I snapped 2 while I was running 24.5/8.5/15 slicks with a LOT more boost than when I made 433 WHP.</TD></TR></TABLE>
on which axles, stock?
Re: stock gsr axles... how much power can they take? (Code Blue)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Code Blue »</TD></TR><TR><TD CLASS="quote">
on which axles, stock?</TD></TR></TABLE>
Stock autozone GSR replacement axles, should have mentioned that. When/If they break again I'm going to use my awesome lifetime warranty and get another set.
some guys have run 10s on stock axles, some break them at stock hp levels. It's all about how easy or hard you are on the car.
Re: stock gsr axles... how much power can they take? (Jared)
i would say its all in the launch, if you baby it out of the hole than there is less of a shock load on the drivetrain and then they might not break as easy, i have had some hard launches at 370ish whp and i thought they where done for shure on my 6500 clutch dump with slicks
Re: (mike1114)
their are a handful of guys that run very well on stock axles. ron went 10s on his stock axle stock diff setup. so they will hold up.
