Hondata Blinking light .. hmmmm
Old Aug 28, 2004 | 04:58 PM
FredoSP's Avatar
Default Hondata Blinking light .. hmmmm
Hey guys, I'm having this really weird thing happen to my hondata blue box (S200b with datalogging).
I have it mounted in the glove box - the red/blank cable going to the Hondata chipped P28 ECU and sometimes I notice when I drive with the glove box open I see the red LED light go on and off. Its not blinking in any fashion just whenever it wants. I tug on the cable to make sure its in there good and sometimes the light with stay on other times it will flash. Also I did notice that if I shake my hondata blue box that the whole circuit board moves, kinda odd, like its not in there good enough.
One more thing ..
The car doesn't stall when the light goes out, its seems fine. Although when Im datalogging and the light happens to flash, the Hondata logging software loses the connection to the laptop and it stop datalogging.
I think Im going to try a new red/black cable first, then maybe if that doesn't help send my blue blox to Hondata and see if they can see anything wrong with it.
You guys experience this or am I just a freak, lol
Old Aug 28, 2004 | 05:00 PM
vietjdmboi's Avatar
my hondata box also rattled when i got it. i just opened it up and used a rolled up piece of paper and stuck it in there. no more rattling now.
Old Aug 28, 2004 | 05:10 PM
EM1 MIKE's Avatar
Default Re: (vietjdmboi)
Mine also rattles a little.
Old Aug 28, 2004 | 05:12 PM
Phil Koury's Avatar
Default Re: (EM1 MIKE)
They all rattle a bit, not really anything to worry about.
You should defenitly check your ribbon cable first (the cable going from the blue box to the ECU). If its not that your pretty much SOL, Hondata 9 out of 10 times will just say its fine and send it back, but you may get lucky.
Old Aug 28, 2004 | 05:30 PM
FredoSP's Avatar
Default Re: (pkoury)
Yeah Im going to order a new ribbon for 15 they said
Thanks guys
Old Aug 29, 2004 | 07:58 AM
FredoSP's Avatar
Default Re: (FredoSP)
ttt
Old Aug 29, 2004 | 09:19 AM
StreetMod's Avatar
I have seen this same problem on a buddies car. Turned out the terminals in the connector at the blue box end were spread apart and not contacting the pins inside the blue box connector. Squeezed these together some and it fixed the problem.
Old Aug 29, 2004 | 12:42 PM
vtec69's Avatar
Default Re: (StreetMod)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by StreetMod &raquo;</TD></TR><TR><TD CLASS="quote">I have seen this same problem on a buddies car. Turned out the terminals in the connector at the blue box end were spread apart and not contacting the pins inside the blue box connector. Squeezed these together some and it fixed the problem. </TD></TR></TABLE>
thats a good thing to check
GReddy SI
Engine Management and Tuning
Aug 12, 2009 08:51 PM
EG6_978
Nov 14, 2008 06:20 AM
sykotik sol
May 31, 2005 03:17 PM
-iLLuZioN-B18C1
Dec 28, 2004 01:06 PM
Griffin@Camtech
Jun 23, 2004 02:42 AM
