ran into some trouble... Few questions
Old 08-26-2004, 09:13 PM
jumpmann23's Avatar
Location: Your really lame if you dock my points, WA, 98033
Default ran into some trouble... Few questions
well i purchased a greddy turbo kit that i was told was for a 00 b16a2 99-00 si. this was perfect for me cause i have a 96 hatch with a 00 b16a2. well today we started on the install and we ran into some issues.
1. i can not bolt up the manifold completely. all but 2 bolts work.. the top middle two bolts seem to be too long for the manifold which makes me believe that this manifold is meant for a gsr.
well thats as far as i got today. didnt really get much done besides the oil pan and t fittngs... but does anyone have an idea on how to go about making this work?
has anyone installed a Greddy GSR kit on a b16a2 in a 96+ civic?
Old 08-26-2004, 09:18 PM
99B16Si's Avatar
replace the manifold bolts with studs and nuts and youll be fine
Old 08-26-2004, 09:20 PM
jumpmann23's Avatar
Default Re: (99B16Si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 99B16Si &raquo;</TD></TR><TR><TD CLASS="quote">replace the manifold bolts with studs and nuts and youll be fine</TD></TR></TABLE>
where can i get the studs and nuts? thanks for the quick response. i was thinking about doing that but idont where to get the studs and nuts from.
Old 08-27-2004, 03:34 PM
jumpmann23's Avatar
Default Re: (Jumpmann23)
k got the studs at a local hardware store...
now im having trouble getting to the two bottom middle bolts. its a really tight fit any tips on how to mount this ******.
Old 08-27-2004, 07:09 PM
jumpmann23's Avatar
bump...
Old 08-27-2004, 07:30 PM
pollito's Avatar
Bore out the holes a little bit if they are tight.
downest
Welding / Fabrication
13
11-12-2010 05:11 AM
redboost10
01-22-2004 08:06 PM
FredoSP
01-19-2004 07:09 PM
Kimbo
04-22-2003 06:13 AM
Quick Reply: ran into some trouble... Few questions
