How to bore out injector seals?
Old Aug 27, 2004 | 11:57 AM
turboteg2nv's Avatar
Default How to bore out injector seals?
I found some article that said to use a dremel to bore out the injector seals to accomodate 450cc's but I can't do it! I tried drilling a hole in a block of wood to hold the injector seal but it wouldn't work. any other injector seal that will fit without modification? Thx
Old Aug 27, 2004 | 12:00 PM
ek_99_SiR's Avatar
Default Re: How to bore out injector seals? (turboteg2nv)
i had an old intake mani in my garage and used the larger dremel tool u put the sand paper things around and just did it that way it worked great
http://www.homemadeturbo.com/t....html
look at that... thats how i did mine
beepy's Avatar
You are trying to bore out rubber O-rings? Don't do that.
Old Aug 27, 2004 | 12:54 PM
Default Re: How to bore out injector seals? (beepy)
THey aren't O-rings, there injection molded rubber seals. I don't happen to have an extra intake mani sitting around though so how else can I bore them out??
Old Aug 27, 2004 | 01:19 PM
Mr_Bojangles's Avatar
I put the seal on my injector, then with some lube squeezed the front of the injectors in a bit, then I just started slowly tightning the fuel rail down, while pressing the edges of the seal in best I could. They are not 100% in, however 4 months later never had a leak or a problem.
90efboi
Apr 23, 2011 07:33 PM
97turboteg
Apr 20, 2006 01:20 PM
THEUSED
Oct 31, 2005 06:36 AM
lowboost civ
Apr 22, 2003 08:47 AM
