well just got back from the dyno now
Old Aug 28, 2004 | 01:20 AM
gowyeng's Avatar
Default well just got back from the dyno now
14# of boost with fully built b16 running gt61s turbo from ITS. I made 253 hp and 167tq at 9000rpm . but didnt even see 14# until 7000 rpms . what is wrong here why such a big lag. Planning to tune to 30# to try for 500hp. Will this turbo lag like this still even at higher boost????? this pos motor is driving me nuts buddy of mine also dynoed his 2.0 stock build also and made 243hp and 247tq at 4000 rpms 4000RPMS at 12# hes running 18g greddy. Is this turbo just to big or do I have some issues?????????? please help not happy with #s at all
Old Aug 28, 2004 | 01:26 AM
gowyeng's Avatar
could it be the cams. the cams are ctr because it came with the head when I bought it
Old Aug 28, 2004 | 02:40 AM
Adi Radoncic's Avatar
On Fire!
Default Re: well just got back from the dyno now (gowyeng)
What size bore are you running?
Do you have any leaks in the system?
Your number is about 100whp lower than they should be.
Honda_Tengoku's Avatar
Default Re: (gowyeng)
do u have cam gears? generally the CTR/ITR cams from what I have heard have too much overlap to make power in vtec on boost. Obviously thats why cam gears are needed to tune the overlap out.
Old Aug 28, 2004 | 05:02 AM
wzcb08's Avatar
More displacement will get you more torque a lot sooner too. B16s can make some good horsepower but torque is not their department, Especially in the low rpms.
Old Aug 28, 2004 | 08:16 AM
93turbo16's Avatar
is your waste gate open? Haha, just a thought.
Old Aug 28, 2004 | 08:34 AM
99B16Si's Avatar
Default Re: (93turbo16)
probably a boost or exhaust leak
Old Aug 28, 2004 | 08:54 AM
XDEep's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gowyeng &raquo;</TD></TR><TR><TD CLASS="quote">Will this turbo lag like this still even at higher boost????? </TD></TR></TABLE>
yes. how high your boost is, is just dependent on your wastegate. unless you have a leak or some tuning problem like they said, your turbine and/or turbine a/r is too big.
Old Aug 28, 2004 | 09:47 AM
22psicrx's Avatar
Default Re: well just got back from the dyno now (XDEep)
does your vtec work. I have a built b16a and at 15psi on the little cam made 253 and 200 torque. when vtec was set it was makink 347 fwhp. hope it helps. what fuel management are you using.
Old Aug 28, 2004 | 09:48 AM
22psicrx's Avatar
Default Re: well just got back from the dyno now (22psicrx)
i have an 18g greddy kit
Old Aug 28, 2004 | 10:53 PM
gowyeng's Avatar
Default Re: well just got back from the dyno now (newgsr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by newgsr &raquo;</TD></TR><TR><TD CLASS="quote">What size bore are you running?
Your number is about 100whp lower than they should be.</TD></TR></TABLE>
stock bore
Mik2006
Aug 13, 2010 11:09 AM
lsturbo*
Mar 29, 2010 05:39 AM
inh
Sep 30, 2007 12:43 PM
2k.civic.si
Sep 28, 2005 12:35 PM
Spooled1.6L
Mar 16, 2004 03:06 PM
