engine does not start
Old Aug 9, 2003 | 02:13 PM
dr_rod's Avatar
Default engine does not start
i have a 92 ls and when i start my engine it runs for about 2 seconds and then stall. I have to wait something like half an hour before i can start it again and it does the same thing. Anyone have had this problem before ? What can be the cause of this ?
thanks
Old Aug 9, 2003 | 04:04 PM
JimBlake's Avatar
Default Re: engine does not start (dr_rod)
Fuel or spark?? Try to narrow it down first. I'll guess that after it's run for 2 seconds & quit, the starter still works. It just won't fire.
If so, watch the tachometer. Is it completely dead or does it bounce? Pull a plug wire & check for spark.
If you have spark and a bouncing tach, then open the gas cap & have someone listen closely while you try to start it. The fuel pump should run for 2 seconds, then it'll keep running ONLY if the ECM sees an ignition signal from the distributor. (That's why I want to know about your tachometer.)
Tell us what you find so we can go from there...
Old Aug 9, 2003 | 04:08 PM
The HamsterBall's Avatar
you might also want to give your battery a load test and check the distilled water level too.
Old Aug 9, 2003 | 04:19 PM
DSayavan's Avatar
Default Re: engine does not start (HamsterBall)
Main relay possibly??? Is it really hot outside when you try starting it?
Old Oct 18, 2003 | 08:37 AM
DIRep972's Avatar
Smarter than you
Default Re: engine does not start (JimBlake)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JimBlake &raquo;</TD></TR><TR><TD CLASS="quote">Fuel or spark?? Try to narrow it down first. I'll guess that after it's run for 2 seconds & quit, the starter still works. It just won't fire.
I am working on a car that is doing this exact same thing right now. All we did was change out the intake manifold and now the car won't start. the fuel pump is priming, we are getting spark, the tb is opening. all the sensors are hooked up right. When we try to start it it dies after about 1 seconed and even if u floor the gas it still dies. When my friend was trying to start it he mentioned the tach jumped up irratically to 3500 on two different occasions. what should i check for next?
GTFODave
Mar 24, 2010 06:14 AM
trevorjohn88ef
Oct 20, 2007 06:55 PM
civic efb16
Aug 8, 2005 09:00 PM
same ol' civic
Jun 5, 2005 07:29 AM
birz
Jul 29, 2004 06:17 PM
