OBD2 and test pipe
Old Aug 10, 2003 | 10:43 AM
rextec's Avatar
Default OBD2 and test pipe
will my 96 integra throw a code if i put a test pipe on it?
Old Aug 10, 2003 | 10:54 AM
MooreBoost's Avatar
Default Re: OBD2 and test pipe (rextec)
Yes, you will need an o2 fooler.
gmoore
Old Aug 10, 2003 | 10:59 AM
rextec's Avatar
Default Re: OBD2 and test pipe (tegunderpressure)
what is that? where can i get one or make one?
Old Aug 10, 2003 | 11:19 AM
MooreBoost's Avatar
Looks kinda like that, its pretty small. You just wire it between the o2 sensor and the ECU. I got that pic off Summit, but I dunno if they have them for imports. Theyre fairly universal I think. Theyre about 50 bucks.
gmoore
Old Aug 10, 2003 | 10:03 PM
96integra20's Avatar
I would say no to that, i have a 96 with obd2 along with a straight pipe and it threw no codes.
Old Aug 10, 2003 | 10:11 PM
VTEC-DA's Avatar
Default Re: OBD2 and test pipe (96integra20)
Mince threw one once, a few days after I put it on. Reset the ECU and it never came back.
Old Aug 10, 2003 | 10:13 PM
B16OnTop's Avatar
Default Re: OBD2 and test pipe (VTEC-DA)
god screw OBD-2 man everytime i get a new mod it throws a code
Old Aug 11, 2003 | 05:12 AM
JDubya's Avatar
Just get an OBD1 ECU and convert it. That's what i did (plus a chip) and i actually noticed a difference in performance. It pulled a lot harder.
Old Aug 11, 2003 | 07:18 AM
The Poopsmith's Avatar
Default Re: OBD2 and test pipe (ALL MOTOR LS)
what you could do is install the o2 bung really close to the wall of the testpipe, so it's out of the direct flow of the exhuast gases. Thats how mine is and it never threw a code
Old Aug 11, 2003 | 09:57 AM
rextec's Avatar
how do you reset an obd2 ecu?
Old Aug 11, 2003 | 12:43 PM
dohc-nyne's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rextec &raquo;</TD></TR><TR><TD CLASS="quote">how do you reset an obd2 ecu?
d/c the battery for about 15 min
Old Aug 11, 2003 | 01:07 PM
u2civic1's Avatar
Default Re: OBD2 and test pipe (dohc-nyne)
can't he grab it in aluminum
Old Aug 11, 2003 | 03:28 PM
asianspeed's Avatar
Default Re: OBD2 and test pipe (u2civic1)
I've got obd2 and a test pipe and I don't throw any codes. The o2 sensor is just zip tied to the shift linkage out of the way. no probs.
Old Aug 11, 2003 | 04:12 PM
SMC Integra's Avatar
For all of you who's CEL goes on with a test pipe, do you have more than one O2 sensor, like the one thats also mounted on the converter. My 94 only has the one sensor mounted in the downpipe. Will this still throw a code with a high flow cat or test pipe?
Old Aug 11, 2003 | 06:41 PM
asianspeed's Avatar
Default Re: OBD2 and test pipe (SMC Rice Rocket)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SMC Rice Rocket &raquo;</TD></TR><TR><TD CLASS="quote">For all of you who's CEL goes on with a test pipe, do you have more than one O2 sensor, like the one thats also mounted on the converter. My 94 only has the one sensor mounted in the downpipe. Will this still throw a code with a high flow cat or test pipe?</TD></TR></TABLE>
no, I believe you have an obd1. so there is no 2nd 02 sensor. so if there is no sensor, it makes it kind of hard to throw a code. Lucky you.
SlammedDC2teg
Oct 14, 2005 05:32 AM
Dai_Ca_Vietnam_H22a4
May 21, 2005 08:42 PM
D-SPEED
Jan 18, 2002 08:30 AM
Ri5e
Aug 14, 2001 03:45 PM
