ARP Torque Specifications
Old Aug 10, 2003 | 08:16 AM
mike34655's Avatar
Default ARP Torque Specifications
I have a 98 Integra GSR and I just took off my head to install new valves. I had ARP head studs in there already and I was going to use them again. What should I torque them too? I was reading an article and it said to torque it to 85 if using oil. Does this sound correct? Thanks for any info you can give.
Old Aug 10, 2003 | 09:19 AM
sander's Avatar
2.7(p/t)
Default Re: ARP Torque Specifications (mike34655)
on mine, i used 72 lbs, with the moly lube. ive gone as high as 75 before, i have no leaks and have very good sealing and coolant pressure.
-sander
Old Aug 12, 2003 | 04:42 AM
mike34655's Avatar
Thanks for the info. Now I can get my head back on to the block and hopefully get the car working again. Thanks
Old Aug 12, 2003 | 06:25 AM
TurboedGSR's Avatar
80lb ft if using regular motor oil
Old Aug 12, 2003 | 01:03 PM
mike34655's Avatar
My friend has some of ARP's moly so I used that and torqued them to 71. Hopefully that will do it. Thanks
Kr4nG
Nov 6, 2009 02:48 AM
hybrid1990crx
11
Feb 20, 2009 02:00 PM
bodydropranger
Feb 3, 2003 03:10 PM
D16A6Turbo
Dec 2, 2002 11:24 AM
saso
Jun 3, 2002 02:57 PM
