sensor question...
Old Aug 8, 2003 | 03:44 PM
untitled's Avatar
Default sensor question...
itsa knock sensor. the ecu reads off voltage and the sensor will only send a certain amount of volts if the engine knocks right? so then if the sensor isnt in the block it see any knock and it wont send any voltage to the ecu and the ecu will think that everything is good? i hav a b18a ls vtec and it has no knock sensor location and i am eventually geting a hondata chip to eliminate knock sensor.
Old Aug 8, 2003 | 03:48 PM
mr.beeks's Avatar
Default Re: sensor question... (88crx91integra)
why would you do that specially for the ls/vtec!!
once the sensor is activated it will retard your timming.
preventing a big booommm (detonation)
I suggest keeping it..
Old Aug 8, 2003 | 03:49 PM
MooreBoost's Avatar
Im sure it will throw a CEL if its unplugged, but IDK what will happen if its just dangling.
gmoore
MooreBoost's Avatar
Default Re: sensor question... (francisco flores)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by francisco flores &raquo;</TD></TR><TR><TD CLASS="quote">
He has no place to put it.
gmoore
Old Aug 8, 2003 | 03:58 PM
mr.beeks's Avatar
Default Re: sensor question... (tegunderpressure)
FYI
there is a way to do this
Old Aug 8, 2003 | 06:43 PM
untitled's Avatar
i dont have the tap. oh and it didnt throw a CEL. its running right now....barely
Old Aug 8, 2003 | 06:44 PM
untitled's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by francisco flores &raquo;</TD></TR><TR><TD CLASS="quote">why would you do that specially for the ls/vtec!!
so your saying ls.vtec knocks more than other motors, no.
Old Aug 8, 2003 | 07:12 PM
mr.beeks's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 88crx91integra &raquo;</TD></TR><TR><TD CLASS="quote">
so your saying ls.vtec knocks more than other motors, no.</TD></TR></TABLE>
if do ls/vtec and raise the comp ratio
you are getting closer to the detonation range.
not only that ls/vtec its more delicate than the other engines
and require more attention.
Old Aug 8, 2003 | 08:08 PM
sander's Avatar
2.7(p/t)
and require more attention.</TD></TR></TABLE>
agreed, dont skimp on something as serious as that.
Old Aug 9, 2003 | 08:07 AM
untitled's Avatar
i lowered compresion. i should of just bought a pw0 and not messed with all this bs.
hondakrazy
Nov 14, 2008 10:42 AM
1.5boosted
Dec 14, 2007 01:45 PM
Big Dick Bandit
Sep 28, 2003 04:54 PM
untitled
Aug 8, 2003 08:03 PM
