Is this true?
Old Aug 11, 2003 | 07:34 PM
IZODIACXI's Avatar
Default Is this true?
STOCK hp STOCK torque S/C hp S/C torque
Acura Integra-GSR 94-01 (150.6) (115.8) (208.1) (153.7)
Acura Integra-Type R 97-01(160.9) (113.0) (209.1) (144.2)
by the way this is a Jackson Racing Supercharger
*All horespower and torque numbers were measured at the wheels on a Dynojet 248E.
If this is the case I'd rather get the GS-R than the Type R? Or is there something im missing? Thanks
Old Aug 11, 2003 | 08:46 PM
TeamTooQuick's Avatar
Default Re: Is this true? (IZODIACXI)
The Type R has high compression that is not meant to be S/C'd or turbo'd. Even the GSR has high compression but its lower then the Type R so it would react better then the R. High compression motors are not meant to be turbo'd or s/c on their stock bottom end....
Old Aug 11, 2003 | 09:07 PM
stolenhubcabs's Avatar
Default Re: Is this true? (TeamTooQuick)
gsr's seem to work pretty well with superchargers since the boost capacity for superchargers isn't that high in the first place
Old Aug 11, 2003 | 09:11 PM
psdvette's Avatar
If you read the chart, you'll see that the Type R is only running 5 psi and the GSR is running 6 psi. That probably is why the R has less torque and about equal horsepower.
Old Aug 11, 2003 | 09:13 PM
IZODIACXI's Avatar
for 1/4 time...is it best to have a gsr or type r?
Is it better if I just get a Type R...make it allmotor and call it quites? Or get a GS-R and put a turbo or s/c in it and call it quites? I know its prob a dumb question but just curious about what others think Thanks!
Old Aug 11, 2003 | 09:17 PM
i think a gsr could actually run 7-8 psi and still be safe, that would account for quite a bit more horsepower, you could also upgrade your pulleys as well
Old Aug 11, 2003 | 09:25 PM
xx dc2teg xx's Avatar
your only focusing speed vs. speed --you gotta remember than the handling in the type-r is crazy
Old Aug 11, 2003 | 09:26 PM
IZODIACXI's Avatar
Default Re: Is this true? (stolenhubcabs)
So if I were to get the jrsc with the works(s/c belts,pulleys,etc.) on a gsr...that will pretty much smoke anything on the street or track right?
Old Aug 11, 2003 | 09:27 PM
Rory Breaker's Avatar
GSRs tend to get better gains from JRSC's. This is mainly due to how finnicky an ITR JRSC setup is. It takes experience, the right mods, and a lot of tuning to get a solid setup. But when you do, it can be just as good as a GSR and moreso.
The ITR is @ 5.5PSI with the stock kit vs the 6PSI GSR kit. And high compression + SC is awesome. Since we are boost limited, we need to make every ounce of power per PSI we can get. A common way to make power is to swap out stock cast pistons for even higher compression forged pistons.
I dont know what I was stock, but I dyno'd at 214/150 conservatively @ 6PSI.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IZODIACXI &raquo;</TD></TR><TR><TD CLASS="quote">So if I were to get the jrsc with the works(s/c belts,pulleys,etc.) on a gsr...that will pretty much smoke anything on the street or track right?</TD></TR></TABLE>
Yep. Anything. DSM's, WRX's, Cobras, Vettes, Ferraris...you name it!
Old Aug 11, 2003 | 09:33 PM
IZODIACXI's Avatar
Default Re: Is this true? (newgsrdriver)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by newgsrdriver &raquo;</TD></TR><TR><TD CLASS="quote">
Yep. Anything. DSM's, WRX's, Cobras, Vettes, Ferraris...you name it!</TD></TR></TABLE>
lol
Old Aug 11, 2003 | 09:35 PM
Dee's Avatar
Dee
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TeamTooQuick &raquo;</TD></TR><TR><TD CLASS="quote">The Type R has high compression that is not meant to be S/C'd or turbo'd. Even the GSR has high compression but its lower then the Type R so it would react better then the R. High compression motors are not meant to be turbo'd or s/c on their stock bottom end.... </TD></TR></TABLE>
My engine is a stock 10.6:1 JDM GSR that loved being boosted. Your comment is a bit twisted since tons of people are (and have been) boosting high comp setups. The correct statement should be: Without proper tuning and the correct fuel setup a boosted high comp engine will not last very long. MiraiZ runs a stock block FMAX boosted JDM ITR and he too has yet to report any engine problems.
Old Aug 11, 2003 | 09:41 PM
roydogg's Avatar
I can't tell?
Old Aug 11, 2003 | 09:54 PM
Default Re: Is this true? (roydogg)
thank you dee, sorry my comment came out wrong...
Ek-Xang
Apr 7, 2010 05:52 PM
bb4 jdm lude
May 25, 2007 08:31 AM
cinq
Sep 17, 2003 09:39 AM
blazin
Nov 26, 2001 12:57 PM
