LS/VTEC knock sensor
Old Aug 11, 2003 | 10:48 AM
ltho1998's Avatar
Default LS/VTEC knock sensor
About ready to start the LS/VTEC and just wondering about the issue of a knock sensor.
I have a 94 LS and will be replacing the head with a B16A1 (1st gen) is there an issue about wiring up a knock sensor?
Old Aug 11, 2003 | 10:54 AM
skribblah's Avatar
Default Re: LS/VTEC knock sensor (ltho1998)
your already going into this the wrong way. please search b/c i can already tell your going to blow your engine.
Old Aug 11, 2003 | 11:19 AM
redlinegsr's Avatar
Default Re: LS/VTEC knock sensor (skribblah)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by skribblah &raquo;</TD></TR><TR><TD CLASS="quote">your already going into this the wrong way. please search b/c i can already tell your going to blow your engine.</TD></TR></TABLE>
skribblah . Its all in how you build it and what components you use. Dont post false opinionated things on this board if you dont know what the hell your talking about.
Now are you currently running an ecu that requires a knock sensor or are you just wanting to add one???
Old Aug 11, 2003 | 11:52 AM
ltho1998's Avatar
Default Re: LS/VTEC knock sensor (redlinegsr)
I'm using a P28 ECU and i'm not sure if my black or the B16a1 has a knock sensor that needs to be wired up.
Old Aug 11, 2003 | 11:54 AM
ltho1998's Avatar
Well the thing ain't in yet.. there's a reason i'm posting because: No related topics were found and I want to know so i DON'T blow up my motor.
Old Aug 11, 2003 | 01:04 PM
l2Y4N's Avatar
you won't need to wire in a knock sensor if youre using the p28 ecu. im using the same ecu on my 94 ls/vtec, but i have an sir2 head.
Old Aug 11, 2003 | 02:34 PM
mr.beeks's Avatar
Default Re: LS/VTEC knock sensor (integraTracer)
even if you dont need to wire it up to the ecu
you could always install it and wire it up to a LED somewhere
in your dash as a safety measure since the LS/vtec is more
sensitive to detonation so you could visit
http://www.c-speedracing.com
and go thru the steps.
if you want its up to your discretion
and here would be the new location for your ks on the block
and -skriblah- is just trying to help on this sittuation since
this subject was already xplored and dont forget new issues
arises and well just debate them to get to a conclusion.
dem0nk1d
Feb 14, 2007 04:03 PM
stinkbox
Jun 13, 2006 08:55 AM
Big Dick Bandit
Sep 28, 2003 04:54 PM
