clutch replacement
Old Aug 9, 2003 | 09:55 AM
ChosenGSR's Avatar
Default clutch replacement
Hey guys, its time to replace the clutch on my teg... I have 123 miles on this baby. I called the dealer and they want 1000 bucks . I dont need the whole assembly, I am guessing just the plate is fine. Any of you guys know a trustworthy place I can have this done around owings mills (MD) area?
Old Aug 9, 2003 | 10:25 AM
gumbybum's Avatar
Default Re: clutch replacement (ChosenGSR)
yeah your garage do it yourself it is very easy and youll learn a lot from it.... i did mine all by myself in my garage it was pretty easy. i can walk you through it if you really need help just IM me
Old Aug 9, 2003 | 11:25 AM
ChosenGSR's Avatar
Default Re: clutch replacement (gumbybum)
it is easy ? paps told me that it requires taking the engine out or the tranny ? sorry i dont really know much about that stuff
Old Aug 9, 2003 | 11:35 AM
00VTEC's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ChosenGSR &raquo;</TD></TR><TR><TD CLASS="quote">it is easy ? paps told me that it requires taking the engine out or the tranny ? sorry i dont really know much about that stuff</TD></TR></TABLE>
depends...
1)if you had a hard time installing an intake...then take it to the shop.
2)if this is your daily driver...then take it to the shop. (this can turn into days w/o having a car for some weekend mechanics)
3)if it's non of the above and if you're willing to learn then, get yourself a helms manual and go for it.
Old Aug 9, 2003 | 11:49 AM
Rice Cooker's Avatar
it sounds like you should take it to a shop. if you had some mechanical inclined friends to help you out you can probably do it in under two hours but, if you've never done it before and don’t have a manual to reference it's best to leave it to a pro.
Old Aug 9, 2003 | 12:02 PM
ChosenGSR's Avatar
Default Re: clutch replacement (Rice Cooker)
hehe, yes i installed my intake alright. my father has been a mechanic (bmw.merc) for years... he never done any of that work on acuras though. what exactly would be involved in doing this ? and can it be done without a lift with only a jack ?
Old Aug 9, 2003 | 12:28 PM
P1mpSlap's Avatar
My car is my daily driver, and I installed it by myself. I have another car I use as a beater car though.
You dont need a lift to do it, but definatly some jackstands, a creeper, and maybe 2 jacks.
IMO, some people can pull the engine out faster than they can pull the tranny while it's in the car. If this is your case, pulling the engine makes it a whole lot faster.
also, if you dont have a helms, you prolly shouldn't atempt this. It's very labor intensive and the helms guides you through it step by step.
Old Aug 9, 2003 | 07:56 PM
Xsi's Avatar
Xsi
If your dad's a mechanic he should have most of the tools etc to DIY and it's fairly straightforward except for getting the tranny on which can be a bit of trial and error.
I did a write up of mine: http://www.integraxsi.orcon.net.nz/clutch
Old Aug 9, 2003 | 10:16 PM
deeweezy's Avatar
where can u find a helms book
Old Aug 11, 2003 | 04:43 PM
SMC Integra's Avatar
Default Re: (deeweezy)
i agree, its a pretty easy and straightforward project, just very labor intensive. I got mine done with the help of a former mechanic in about a week. I had to replace lots of rusted and corroded parts so it took a little longer. We didn't have an engine hoist, only 1 jack, and two jackstands. We didn't have to pulle the motor or trans either. You can just undo a few of the motor and trans mounts and there is enough room to slide the tranny off the engine. Make sure you get 3 or 4 strong freinds to help when it comes time to separate the two, the tranny is very heavy and aquard to manuver. Good luck
Old Aug 13, 2003 | 07:16 AM
ChosenGSR's Avatar
Default Re: (SMC Rice Rocket)
would it be ok to just replace the disc itself and adjust the pedal ? I got one by exedy... I am low on funds.
Old Aug 13, 2003 | 07:29 AM
fivespeedintegra's Avatar
you really should get a kit that has a new pressure plate and everything.
don't want to have to open up the tranny twice, do you?
Old Aug 13, 2003 | 07:39 AM
ChosenGSR's Avatar
Default Re: (fivespeedintegra)
I am selling the car in less than a year, I just dont want clutch slippage
veritasaequatis
Jan 22, 2007 08:33 PM
sockvtec
Oct 16, 2005 03:49 PM
rocco
35
May 10, 2004 12:45 PM
94si94cx
Oct 1, 2003 10:15 AM
TheBaron
Apr 20, 2003 02:26 AM
