Quick question
Old Aug 8, 2003 | 06:35 AM
FK00GSR's Avatar
Default Quick question
Ok before anyone says do a search i already read about 70 of them. But I just had a quick question my abs light keeps coming on occasionally and one of the solutions from what i gather is fill up the with brake fluid now the question is when you look at the container it has a min and max should i fill it up to the max it is currently in between the min and max right now so should i fill it up more?
Old Aug 8, 2003 | 07:26 AM
jolt-tsp's Avatar
Default Re: Quick question (FK00GSR)
if you're anywhere in between it should be okay. Might want to fill it up to max just to be sure anyway.
One thing I learned from the Simpsons a while back, to get rid of the light, just put a peice of black tape over it =P
Old Aug 8, 2003 | 08:48 AM
JimBlake's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FK00GSR &raquo;</TD></TR><TR><TD CLASS="quote">... it is currently in between the min and max right now so should i fill it up more?</TD></TR></TABLE>
NO.
Since you tell us your ABS fluid reservoir hasn't run empty, then the light must be coming on for another reason. Got a Helm manual for you car? You can pull codes from it to see what it thinks is wrong. Is the pump running too often? Does it run too long? Maybe you need to bleed air out of the accumulator?
frossteedhehe
Suspension & Brakes
Feb 22, 2013 10:00 AM
daddy
Honda Civic (2001 - 2005)
May 29, 2007 09:02 AM
khenning
Oct 15, 2004 11:33 AM
caliskier
Jul 9, 2004 09:59 AM
Solipsist
Jan 27, 2004 09:33 AM
