LS VTEC HELP!!!!!!
Old Apr 28, 2012 | 06:01 PM
jose12889's Avatar
Default LS VTEC HELP!!!!!!
HEY HONDA-TECH. LS VTEC WILL NOT LINED UP. NEW GSR WP,TENSIONER,BELT FROM DEALER. TRIED IT EVERY POSIBLE WAY. THIS IS MY FIRST LS VTEC NEVER HAD PROBLEM PUTTING TIMING ON MY BUDDIES GSR,OR B16. TOOK THE AEM CAM GEARS OFF PUT STOCK GSR AND SAME
RESULTS.
HERE A PIC THE REAL QUESTION IS: WOULD IT AFFECT ANYTHING?..
Old Apr 28, 2012 | 07:19 PM
civic ef's Avatar
Default Re: LS VTEC HELP!!!!!!
Well me n my brother had the same problem on a y8 and we tested but it had a huge valve leak so don't move it in till u get it right
Old Apr 28, 2012 | 07:43 PM
civic ef's Avatar
Ok here is a link that can help u
https://honda-tech.com/forums/all-motor-naturally-aspirated-44/lsvtec-timing-off-half-tooth-2296920/
Old Apr 28, 2012 | 07:46 PM
crash parker's Avatar
look ontop where the cams go threw the head into the cam gears there are is a little hole about an inch inward from the gears you will need to aline the hole on the cam holder with the hole threw the camshaft it takes a .05 in rod will hold inplace for you to put the belt on. putting the rod in both will line the gears up
Old Apr 28, 2012 | 08:12 PM
jose12889's Avatar
it has no holes thats only in old integras
Old Apr 28, 2012 | 08:14 PM
jose12889's Avatar
im good at puttting timing never had this prob like i said my first ls vtec. all i know a measure my gsr block and this one the gsr is one cm longer
Old Apr 29, 2012 | 09:45 PM
scottypippen147's Avatar
have you tried turning one of the cams one more time? my friends engine was like this but we turned one of the cams and then it lined up properly
Old Apr 29, 2012 | 09:49 PM
yungkhmer's Avatar
turn the exhaust side a tad and it should make it line up.
Old Apr 29, 2012 | 10:28 PM
rayray14's Avatar
I had the same issues with my old LS/V setup, hated having to time it. I could eventually get them to line up just took FOREVER.
almostjdmeg
Jul 26, 2008 09:15 PM
dem0nk1d
Jan 29, 2007 07:53 PM
