Which mount is this?
Old Apr 26, 2012 | 02:34 PM
TOO MUCH TORQUE's Avatar
Default Which mount is this?
i need the mount thats next to the oil pan. someone said this mount helps with shifting on manual transmissions..is this true?
Mine is deteriorating.
http://www.acuraoemparts.com/delray/...All&vinsrch=no
is it number 14?
Old Apr 26, 2012 | 02:40 PM
Fliptard's Avatar
Default Re: Which mount is this?
its a torque mount, bolted the the AC bracket and the the underside of the car. It is so the motor can't "torque back and forth. Yes it will pop your tranny outa gear without them, as well as jerking the engine around and causing stress and wear on the motor mounts.
Old Apr 26, 2012 | 02:58 PM
thanks man. 14 is the driverside right?...just making sure
where is number 12 located on the car? i want to take a look at the one too and replace if necessary
Old Apr 26, 2012 | 02:59 PM
Fliptard's Avatar
bracket bolted the the front side on the tranny, bolting in the same spot under the car, just on the pass side instead of the drivers.
Old Apr 26, 2012 | 03:43 PM
racebum's Avatar
the energy inserts help a LOT with this problem. the oem mounts are really too soft for any kind of performance driving.
you can also get the avid kit for $100 which comes with the 2 lower mounts, poly bushings in an aluminum shell
Old Apr 26, 2012 | 05:39 PM
although this sounds nice, im not willing to give up a near vibration free cabin! Oem will be just fine.
Old Apr 26, 2012 | 06:05 PM
racebum's Avatar
they aren't. even new they slap on hard downshifts. i THINK the type r mounts are a bit stiffer if you're hell bent on staying sloppy
Project_EK
Jun 2, 2006 07:06 AM
wantboost
Nov 12, 2005 11:03 AM
LiL accORd RideR
Jan 21, 2005 03:15 PM
Casey
May 24, 2002 05:23 AM
CIVIX
Mar 18, 2002 06:03 AM
