Electrical Problems.
Old May 9, 2012 | 07:26 PM
dillie's Avatar
Default Electrical Problems.
ok so my friend bought a 94 integra and the harnesses were hacked to crap so we found a donor car with a engine and harnesses, the body was beat up so we decided to swapped all the harnesses....now we cant get any spark BUT after you stop turning the key after you crank it, the last rotations it sparks....if that makes any sense idk how esle to explain it, and the injectors are not pulsing and the fuel pump is running....i have no clue what esle it could be i have checked everything in the world everything we changed i made sure was back in correctly, does anyone have any ideas on what it could be??
Old May 9, 2012 | 07:49 PM
B20ztek's Avatar
Default Re: Electrical Problems.
Was the car a 95/95? Im assuming so since the engine harness is plugged up and you get some kind of spark.
You said you checked everything, when were the plugs/wires changed? Rotor, distributor?
As far as injectors, check the main relay harness for power on 3 wires when key is in the "on" position
gs-r94coupe
Oct 22, 2010 10:06 PM
bradennicely
Apr 18, 2010 05:10 PM
nycuban87
Jan 11, 2010 11:01 PM
CivCruise
Oct 10, 2009 08:33 PM
filip-s
Oct 26, 2006 07:22 AM
