Extra Plug on OBD1 harness.. please help.
Old May 1, 2012 | 08:21 PM
Ride Da Fire's Avatar
Default Extra Plug on OBD1 harness.. please help.
I really need some help from you guys, I already did my research and I did not find any weird case like mine. Long story short. I bought a 96-97 JDM GSR and down graded it to OBD1. Bought the OBD1 harness from a guy in the car forum that I was a member in. Last saturday after I installed the engine and try to plug all the wires together and ran across this one PLUG that I circle in RED, the wires color on that plug are green and red. I do not know what that plug for. I look around the engine and there is no more extra plug to plug that in. Thanks in advance.
Old May 2, 2012 | 03:45 AM
TheRealTegger's Avatar
Default Re: Extra Plug on OBD1 harness.. please help.
What year/vehicle did the harness come out of?
Old May 2, 2012 | 05:19 AM
el crapitan's Avatar
could run the car and check the codes. that should tell you
Old May 2, 2012 | 05:48 AM
Solster's Avatar
Thats An EZ one it's the ECT or Engine Coolant Temp sensor the color combo of the wires and the connector are a match.
now thare are 2 spots for this the bottom center of the head and the thermostat housing. the ECT should be in the bottom center of the head and the other is the Rad fan swith both use the same connector but the wire colors are noth the same
Old May 2, 2012 | 01:54 PM
He said it came off of the 95 GSR
I'll try that
I'm gonna go under the car and look again.
thanks all for your help, I really appreciated that.
Old May 2, 2012 | 01:55 PM
mouab18c1's Avatar
You don't need to get under the car. It either plugs to the side of the head or onto the thermostat housing where the ECT sensor is located.
Old May 2, 2012 | 03:36 PM
Thats An EZ one
What's an "EZ"?
OP clearly already has an ECT connector on the thermostat housing in his pictures. Wonder what those wire colors are...
I don't have wiring diagrams specifically for the '95 GS-R, but all other Integras of that vintage appear to have different-colored wires than red and green.
Old May 2, 2012 | 03:56 PM
kchungb17a's Avatar
Peel back the tape a little to get a better look at the wire colors.
If it is red/yellow and green/blue (I think I can see a little bit of yellow on the red wire in the pic), it's for the intake air temp sensor. My diagram notes that it is at the center rear of engine but it should be on the intake manifold.
BUT, if it is red/white and green/blue then it is for the ECT sensor. Which would mean you have the wrong plug connected to the ECT sensor in your pic.
And I would hardly call going from OBD2 to OBD1 a down grade, but that's beside the point.
Old May 2, 2012 | 05:05 PM
fcm's Avatar
fcm
Old Fart
94-97 Integra...
ECT sensor - red/white and green/blue, to ECU/ECM.
ECT sending unit - yellow/green, to temp. gauge in cluster.
ECT switch - green and black, to rad fan relay, [black to ground].
Sorry, not sure where thet are mounted on a 96-97 JDM B18C. 94
Old May 2, 2012 | 07:47 PM
Ok that plug is for Vtec Oil Sensor on USDM, JDM doesn't have a Vtec Oil sensor.
here is the pix for it.
what am I going to do with that plug? cut it off?
Old May 2, 2012 | 08:23 PM
fcm's Avatar
fcm
Old Fart
Do you mean VTEC pressure switch, are the wires on the plug blue/black and black?
What ECU/ECM are you using?
My guess is because it is just an on/off ground supply pressure switch, you would need to jump the connector so ECU/ECM "sees" the ground, [engine has oil pressure]. 94
Old May 3, 2012 | 05:24 AM
I bought a USDM GSR ECU from EBay and that's what I will be using.
Old May 3, 2012 | 05:46 AM
kyden's Avatar
the vtec pressure switch has always been a green plug. did the previous owner splice a new plug in?
Old May 3, 2012 | 07:37 PM
I'm not sure if he did or not, Im off this weekend. I'll cut away all the electrical tape and find out.
If in bad case of scenario I'll or a SKUN2 Vtec solenoid because the OEM vtec solenoid is cost $260 + shipping.
Old May 4, 2012 | 04:47 AM
HondaPartsHero's Avatar
Technical Hero
JDM-R
Nov 12, 2014 02:40 AM
ja20_eg
Apr 4, 2012 07:17 AM
94-integra-ls
Sep 17, 2009 05:23 AM
1BADEGDC2
10
Oct 1, 2007 10:02 AM
string
Aug 26, 2005 10:29 PM
