where do these vacuum lines lead to?
I am having idle issues and I believe I found the causing leaks, but not sure where these lead
to. Any help and pictures would be nice. Thanks in advance!
I also have this open. When I have the car started and cover this it stalls out. But the vacuum line from the other hoses arentt long enough to reach this.
Re: where do these vacuum lines lead to?
I think IM missing something. I have a LS Vtec..
After looking at a vacuum line diagram seems like missing the evap purse control canister?
You need to plug up at least the one in the manifold. It's making your motor run lean, and your map sensor is not reading that amount of air entering the motor.
Those other two from the first picture are from the charcoal canister. The smaller one goes to the purge solenoid and the bigger one goes to the top of the throttle body where there is a black nipple already on it.
Yeah IM trying to figure out the one on the manifold goes to. When my car is running I hear it sucking a lot of air. I cap it off it shuts right off so it has to connect to something.
Hype-R Stalker
The small nipple coming off the back of the manifold needs to be blocked off,
it's sucking air all the time bypassing the throttle body.
Depending on what kind of ecu/tune you have, your car may run funny if it's a stock gsr.
Also may want to check your IACV on the back, you'll have idle issues that seems like a vacuum leak if it's dirty.
It is connected to the purge solenoid. You need a short hose from manifold to the bottom of the purge, and on top of the purge goes the long small diameter hose that you showed in the second pic.
U stand correct ones more i would jz do what cleanlikejdm Thats seems like the best option
Sorry guys i am DA guy and kind of new to tegs. sorry
Cleanlikejdm...
When Its blocked off... the car starts but it dies right away. When its left open it stays running but sputters.
roll8221
Engine Management and Tuning
04-01-2015 11:29 AM
