VAFC/SAFC/FIELDSFC...?
Old Apr 9, 2002 | 05:54 PM
ion_four's Avatar
Default VAFC/SAFC/FIELDSFC...?
So, does the VAFC have any other features than changing vtec engagment that the SAFC doesn't? I'm planning on running a stock cam, atleast for a while and won't need that, will I? Also, the Fields SFC seems a little oldskool and basic, but does it get the job done of changing the fuel and vtec?
I'm looking to avoid an fmu and going to run 5-7 on a stock d16z6, with (not quite as little) 290cc's...maybe a better pump, too. Possible? oh, I also have an fpr...
[Modified by ion_four, 2:55 AM 4/10/2002]
[Modified by ion_four, 7:45 AM 4/10/2002]
Old Apr 9, 2002 | 10:46 PM
ion_four's Avatar
Default Re: VAFC/SAFC/FIELDSFC...? (ion_four)
question answered about the VAFC, but what does everyone think of the fields? Can you do a hack for boost like the safc/vafc?
Old Apr 11, 2002 | 06:46 AM
rioninja's Avatar
I have not used a fields unit, but i have been told it only allows -30% fuel tuning, as compared to the -50% of the Apexi units. At -30 to -40, my DSM 450s run optimal. This is at stock fuel pressure.
The fields would work well with slightly smaller injectors, or with the DSMs if you lowered fuel pressure via an FPR. The only drawback i think, is that the less you decrease the map signal, the less room for boost your gonna have. While at -40% people are able to get 10psi, at -30% you will only be able to run about 7psi or so.
seanjohn81
Jan 23, 2007 04:46 PM
devonic
Apr 24, 2003 06:18 AM
red cx
Nov 12, 2002 03:39 PM
redteg1
Feb 6, 2002 09:15 PM
Mike95lude
Oct 10, 2001 10:53 AM
