opinions on boost controller
Old Apr 8, 2002 | 07:21 PM
Aeka GSR's Avatar
New User
Default opinions on boost controller
Someone was telling me that the Apexi SUPER AVC TYPE-R was CRAP. Is this true? I was wanting to get one because of all the extra monitoring devices that it has and because it is electrical, am i wasting my money?
Old Apr 8, 2002 | 08:36 PM
Aeka GSR's Avatar
New User
Default Re: opinions on boost controller (Aeka GSR)
*bumpasaurus*
Old Apr 8, 2002 | 08:40 PM
dustin's Avatar
I really like mine, I could not live without the peak hold function on it.
It takes work to get the thing to maintain boost consistently, though.
I'd buy it again for sure.
Dustin
Old Apr 8, 2002 | 08:43 PM
Aeka GSR's Avatar
New User
Default Re: opinions on boost controller (dustin)
how so? I'm a giant dumb newbie!
Old Apr 8, 2002 | 09:06 PM
Aeka GSR's Avatar
New User
i also just asked around and i heard that sometimes it gets stuck in learning mode and then overboosts the turbo because it's not opening the wastegate in time.
Old Apr 8, 2002 | 09:28 PM
dustin's Avatar
Mine has never been stuck in learning mode.
You just need to make sure the start duty is set to a number that is VERY close to the actual target duty.... and then just drive the car.
People run into issues with the AVC-R when they try to run really high boost on really low rated boost springs (aka, 18psi on 4psi wastegate spring...)
Dustin
Old Apr 8, 2002 | 09:31 PM
LsTurbo91's Avatar
Dustin
Sir, are you reffering to me hehe
Yea, the avcr is not for the weak minded If you want something simple go with a profec B
Old Apr 8, 2002 | 09:32 PM
dustin's Avatar
Default Re: opinions on boost controller (LsTurbo91)
Actually I was referring to someone else... but if the shoe fits!!
LsTurbo91's Avatar
Indeed!
Old Apr 8, 2002 | 09:42 PM
Aeka GSR's Avatar
New User
thanks guys, what about the blitz SBC i-D?
Old Apr 8, 2002 | 09:54 PM
Aeka GSR's Avatar
New User
i talked to the guy again and he said that two maxima's were running at 9lbs and the thing started boosting waaaay the hell over 10. I don't know how they set the start and target duty
Old Apr 8, 2002 | 10:01 PM
dustin's Avatar
They may have connected the actuator up wrong.
Old Apr 8, 2002 | 10:02 PM
Aeka GSR's Avatar
New User
oh and does this thing work for internal wastegates?
Old Apr 8, 2002 | 10:07 PM
dustin's Avatar
Yes.
Old Apr 8, 2002 | 10:08 PM
Aeka GSR's Avatar
New User
ok nevermind guys...... the guys i found out hooked it up wrong to the wastegate.....
oh and dustin, i have found you to be the most useful resource here on honda-tech.
[Modified by Aeka GSR, 11:10 PM 4/8/2002]
Old Apr 8, 2002 | 10:10 PM
InfamousRS's Avatar
so is it better to run a high boost spring in the WG over a low boost spring when using a boost controler?
Also, what are some of the functions of Apex SUPER AVC-R?
[Modified by BLK94RS, 11:32 PM 4/8/2002]
Old Apr 8, 2002 | 11:47 PM
PROFILES2000's Avatar
Default Re: opinions on boost controller (BLK94RS)
does teh boost cylonoid on the AVCR supposed to make a buzzing vibrating sound when the car makes boost? ( i didnt notice it untill i installed my AVCR)
Old Apr 9, 2002 | 01:29 AM
TurboIntegra's Avatar
Default Re: opinions on boost controller (TurboGsR.com)
No it should not buzz at all.
I highly recommend the AVC-R.
You do not have to be a rocket-scientist to use it. It is fairly easy IF you read the directions.
I love the features it has . Some of my favorite are:
Boost different amounts at different RPM's.
Boost different amounts in different GEARS. (Meaning in 1st gear I actually turn down my boost so that I can get traction, then after I lock up it hits full boost)
Old Apr 9, 2002 | 01:41 AM
SIK IN DA HED's Avatar
New User
Default Re: opinions on boost controller (TurboIntegra)
the only reason why it doesnt work good for them... is because they didnt know how to use it right or probably didnt do a good job of installing it. those controllers are the best ones on the market. i prefer the profecB. turn the **** til you get the boost you want, while sittin in the car listening to some beats.
Old Apr 9, 2002 | 07:45 AM
Mr. Vapor's Avatar
Default Re: opinions on boost controller (dlplayboy)
can someone give me a quick run down on the gear judge function.....im still learning, what types of baseline #s should i be programming in for my turbo'd Si?
Old Apr 9, 2002 | 07:49 AM
GSRwBOOST's Avatar
i agree
B_1_8_hatch
Oct 6, 2003 12:01 AM
Snafu-Si
Mar 5, 2002 02:07 AM
teamrocket si
Feb 10, 2002 02:27 PM
riot
Feb 1, 2002 09:33 AM
