Missing link?
Old Apr 9, 2002 | 09:20 AM
Evil EG's Avatar
Default Missing link?
Ok I just got my turbo installed! I started up the car today and it seems to be idleing funny.
I haven't driven it, but when im in the garage, I rev it to like 2500rpm's and when It comes back down to idle it almost wants to die. But when I take out the missing link and use just the map sensor its fine. Is this normal, do you have to break in the missing link or something? BTW the check engine light is on too.(but i think its the o2 sensor on the cat cause i dont have the downpipe on the cat yet.)
Any Ideas?
-thanks
[Modified by BVM, 6:22 PM 4/9/2002]
Old Apr 9, 2002 | 10:45 AM
TURBOED-TEG's Avatar
Default Re: Missing link? (BVM)
The car will go into limp mode if that map sensor "sees" boost so the only way the missing link is the problem is that you installed in upside down if that is possible. Also what car is this turbo on and what all is install with it? Is your car OBDI or OBDII? Give me some more info I can try to help better.
Old Apr 9, 2002 | 10:49 AM
Evil EG's Avatar
Default Re: Missing link? (TURBOED-TEG)
I have a 00' Integra GSR.
DRAG Gen III kit.
Airtex Fuel Pump
Vortech FMU
Old Apr 9, 2002 | 10:52 AM
teg2snbtrbd's Avatar
I don't think you install the missing link upside down, the map sensor won't plug into it.
Old Apr 9, 2002 | 11:10 AM
Default Re: Missing link? (teg2snbtrbd)
Since you are OBDII hook up the downpipe and see if that helps since there is an O2 sensor downstream in the Cat this is most likely screwing up the car's idle. If this doesn't work check for vacuum leaks in all your new connections
Old Apr 9, 2002 | 11:53 AM
turbogsr13z's Avatar
same thing happened to my car its like dat and i dont know why it ildes weird like i have cams and when i give it gas it almsot chokes on me when it goes down to 300 rpms it almost stalls in idle, it mite be my plugs or head gasket i dont know
Old Apr 9, 2002 | 12:20 PM
Default Re: Missing link? (turbogsr13z)
Did you put new plugs in it? If so are they 2 degree ranges colder? Did you close the gap any? You need to close the gap a bit, just a few thousanths.
Old Apr 9, 2002 | 12:55 PM
Evil EG's Avatar
I just checked my plugs and they had oily deposits on the im gunna go get new ones... What kind should I get?
Old Apr 9, 2002 | 08:17 PM
turboex's Avatar
get ngk BKR7ES-11 and gap them to .030 tehy work great
nicktagz
Sep 24, 2006 05:38 PM
Treblarefils
Feb 23, 2005 11:26 AM
integraracer94
May 23, 2002 04:19 PM
yellow blur
May 21, 2002 09:52 AM
