installin check valve on 98 civic?
where do you put it? i knoit connects to the map sensor but the map sensor is on the throttle body and there are no vacuum lines for it. so where should the check valve go?
Re: installin check valve on 98 civic? (psicrxsi)
what kind of check valve setup do you have?
if just the check valve t's and hoses? pull the map off the hook a hose the the sensor. and plug the old location up.
Johnny_Rocket
04-11-2005 12:35 AM
