Fuel pumps
Old Apr 10, 2002 | 05:03 PM
dwilson's Avatar
Default Fuel pumps
I am installing my kit this wkend and have a small problem. I am going to be running with the 12:1 FMU for a while. What i needed to know is i have the Inline Pump that come with the kit and have also purchased a Walbro 255 Hp intake pump. Which pump should i use? I have a Ls motor in a 93 hatch, BUT still have the Dx pump in the tank. I have heard that if u use the inline pump with that little pump it will pull it dry so which pump or what to do for time being. I will only be running stock 6.5 psi until i upgrade to some larger injectors and a standalone. I just want to get the kit on and tuned.
Old Apr 10, 2002 | 07:15 PM
shadowdawn's Avatar
Default Re: Fuel pumps (dwilson)
I would recommend the stock intank with the inline, what will do you fine around 7psi
Old Apr 10, 2002 | 08:41 PM
Hondata's Avatar
Make sure you have read, and understood, the dangers of high fuel pressure, and the capabilities of the stock fuel pump.
http://www.hondata.com/techfuelpump.html
technine
May 22, 2009 05:38 PM
lucas569
Feb 17, 2002 02:21 PM
austrian type-R
Jan 25, 2002 12:38 AM
LudeSi-93
Jun 25, 2001 04:19 PM
