which walbro fuel pump do you guys run with hondata
New User
550cc injectors....and hondat 2b.....which fuel pump do you run with this?
gss317?
gss342?
i just got the gss317, and i think you are suppose to use gss342 which is high pressure. Let me know which one I am suppose to use. Thanks
gss317?
gss342?
Re: which walbro fuel pump do you guys run with hondata (Arturbo)
gss342.
http://www.importpoweronline.com/walbro.html
This is the same guy that you can get RC 550s for $270 shipped. Its in my sig....
Re: which walbro fuel pump do you guys run with hondata (93LSivic)
you guys think that pump is really needed w/ big injectors such as 440's & 550's? i always thought the regular walbro was good enough...
New User
FAWK!
oh well, i just ordered the gss342. thanks 93LSivic...
i guess i'm returning the gss317 tomorrow.....
Re: which walbro fuel pump do you guys run with hondata (integra7)
New User
Re: which walbro fuel pump do you guys run with hondata (lucas569)
I think i'm just gonna be safe and run the one that can handle more pressure.
plus...105 shipped is less than i paid for the gss317
1 Post
how come ben at importparts told me that the airtex fuel pump with the drag 3 kit will be sufficient?????????
I am gettin 440's with hondata, any suggestions? please help me out, I am in the process of ordereing everything right now. Thank you
Re: which walbro fuel pump do you guys run with hondata (intekragsr)
The inline is fine, but the inline is only used to protect your from the high fuel pressures of the fmu. With hondata, you shouldnt have to run extremely high fuel pressures. The intank isnt a must, but its just it makes the engine bay look so much better.
art
art
New User
i got the walbro gss317 from http://www.autoperformanceengineering.com -- it was like $95 or $100 shipped
Re: which walbro fuel pump do you guys run with hondata (Xerxes)
I think with the fuel pressures you'll see with the Hondata, the GSS317 or the GSS342 will work fine. I would be concerned about using the GSS317 though with a FMU setup because of the super-high fuel pressures.
holley / walbro 12-916 0r 906 is enough both pump 255lph at 43.5psig
Re: which walbro fuel pump do you guys run with hondata (rtype11)
you don't need to run the high pressure pump for hte hondata or any stand alone like you would with an fmu set-up.
hondata claims some of the stock oem fuel pumps can handle close to 350whp.
but obviously no one ever tries.
New User
Re: which walbro fuel pump do you guys run with hondata (bgod)
you might be able to get 350whp with bigger injectors; with 440ccs my pumped was MAXED OUT at 240whp.
-Xerxes
-Xerxes
turbolsvtecej1
09-07-2014 04:06 PM
TurbothisLS
08-28-2002 07:57 AM
