MAP sensor bypass?
Old Apr 9, 2002 | 12:40 PM
Mr.NiceGuy's Avatar
Default MAP sensor bypass?
Hello all. I have a question about the map sensor on a SOHC VTEC 93 civic. Is there a way to bypass the map sensor not to read boost and only keep vacuum for the Map sensor? Ive researched that a way to do it is to put a "check valve" on it to keep the vacuum going one way consistantly. could you please help me?
Old Apr 9, 2002 | 12:45 PM
Pritos's Avatar
New User
Default Re: MAP sensor bypass? (Mr.NiceGuy)
Instead of saying, "do a search" (is it working already?) I'll go ahead and tell ya!
Invest in a Missing Link. importparts.com that will cure your problem and look oh-so-pretty.
Or buy plastic tee's and hook up 2-4 Aquarium fish-tank check valves to the map. I believe your map is on the throttle body? You'll need to remove your map, then just take a Tee and shove it in the hole. Its a wonderful friction fitting. hook up your check valves off of it.
i prefer the latter.
[Modified by Pritos, 1:47 PM 4/9/2002]
Old Apr 9, 2002 | 12:57 PM
teg2snbtrbd's Avatar
Get the missing link. I got one and it runs like a champ.
Old Apr 9, 2002 | 02:36 PM
Mr.NiceGuy's Avatar
thanks guy
shaggyeg6si
May 15, 2008 07:48 AM
Carbcivic
Mar 14, 2007 05:55 AM
_VTI-R_
Feb 28, 2003 01:44 PM
