eagle rod question
Old Apr 10, 2002 | 05:29 AM
MackSpeed-616's Avatar
Default eagle rod question
whats the tq. spec for eagle rod?
if it matters its a b18c
[Modified by Mr. Bait-R 616, 11:28 AM 4/10/2002]
Old Apr 10, 2002 | 07:12 AM
DR. ON POINT's Avatar
Banned
Default Re: eagle rod question (Mr. Bait-R 616)
TTT
Old Apr 10, 2002 | 07:22 AM
BROOD's Avatar
I believe it to be 28 ft-lb for Eagle rods.
Old Apr 10, 2002 | 08:30 AM
Dublocivic's Avatar
Default Re: eagle rod question (On Point EK)
For ARP 2000 5/16" use 28ftlbs
.0048-.0052 on the bolt stretch if you use any lube other than ARP moly assembly lube.
Rod to crankshaft clearance should be .0015" - .0017"
and last but not least pin to bushing clearance should be .0004" - .0006"
--Adam
Old Apr 10, 2002 | 09:41 AM
blueciv69's Avatar
From the honda service manual. 0015 to 0020 service level is 0024
Old Apr 10, 2002 | 11:06 AM
Dublocivic's Avatar
Default Re: eagle rod question (blueciv69)
That is the spec for OE rods.. you have to run a bit on the tighter side with the eagles.. like I said .0015-.0017
infumis
Jan 12, 2007 07:41 AM
94CivSi
14
Apr 15, 2004 04:34 PM
shiftgear8000
Mar 19, 2004 10:09 PM
asubennett
Mar 1, 2004 11:16 PM
ladysman
Apr 15, 2003 04:20 PM
