if u have bad ring/ringlands .......
Old Apr 10, 2002 | 08:26 PM
Cyber ITR's Avatar
Default if u have bad ring/ringlands .......
u will lose compression right , does that mean ur car slower @ low or hi revs ??
or both ??
thanks guys
Old Apr 10, 2002 | 09:05 PM
Ri5e's Avatar
Default Re: if u have bad ring/ringlands ....... (VTEC_SiR)
your car will have low compression. It may even stall out or idle really crappy when you stop the car. And the car will feel crappy through RPM band. But it really depends on how bad the compression readings are. If they are really low, the car won't even start up or have a really hard time starting up.
Old Apr 10, 2002 | 09:18 PM
earl's Avatar
If lands bad, u suck oil right from the pan into the chamber. Car will lay out a smoke screen. Usually happens from mistuning with stock pistons
Old Apr 10, 2002 | 09:50 PM
Cyber ITR's Avatar
Default Re: if u have bad ring/ringlands ....... (BG Boost)
piiiufffff , mine doesnt do any of that
just a lil bit less responsive , prolly cuz too hot da weather
Old Apr 10, 2002 | 11:23 PM
98Psi ITR's Avatar
What's the compression? Have you physically checked the ringlands?
Old Apr 11, 2002 | 04:43 AM
Cyber ITR's Avatar
Default Re: if u have bad ring/ringlands ....... (98Psi ITR)
210 210 200 210
well this is a '93 B18C JDM , old never rebuilt =P
nope i havent open da head and check it physically ??
why is that ?!?!?!
very hardly blowin blue smokes
Old Apr 11, 2002 | 05:45 AM
VTC_CiViC's Avatar
With that kind of compression, your rings are fine. If your smoking blue, your oil control rings may be seizing up or perhaps you have leaking valve seals.
Old Apr 16, 2002 | 11:00 PM
Sh4rky's Avatar
Default Re: if u have bad ring/ringlands ....... (VTC_CiViC)
How much are the rings, say for one piston (96 GSR)? How about the labor? Does it take long to do?
THanks!
jdmek2277
17
Feb 2, 2009 08:12 PM
djtony5
Oct 25, 2004 09:16 AM
VNTEC
May 22, 2004 08:23 PM
