Power to the fuel pump
Old Apr 8, 2002 | 12:35 PM
Evil EG's Avatar
Default Power to the fuel pump
I got the airtex pump from the drag three kit.
I need to know where to connect the power for the pump at. Does it connect to the fuse box or what? Please be very discriptive or show me pictures thanks alot.
00' Integra GSR
Old Apr 8, 2002 | 03:34 PM
Evil EG's Avatar
Default Re: Power to the fuel pump (BVM)
I know you guys have the awnser...
Ill be up and running I just need this.
thanks
Old Apr 8, 2002 | 03:43 PM
b18bturbo's Avatar
connect it to the fuel pump relay that is located under the dash you shoud be bale ot here it click whe nyou turn the key on. The other alternative is run it an accesory with an inline fuse
Old Apr 8, 2002 | 10:30 PM
turbopimp's Avatar
Yup, as B18bturbo says, locate the main relay. It's usually under the instrument cluster on most Hondas but on newer Civics and Si's it's located under the dash closer to the passenger side. You can hear it clicking on and off if you keep cycling the ignition key between ignition 1 and ignition 2 positions. The wire you want to tap is usually pin 7 or pin 4 on the relay (yellow/black stripe). If you are unsure which wire is the correct one, use a test light and see which wire lights the test light for about 1 sec, then turns off when you turn the ignition key from ignition 1 to ignition 2. You'll see hear the factory pump buzz on and off in tandem with the light when you find the correct wire.
EG MikE
Jun 1, 2009 01:36 PM
killingtwobirds
Sep 17, 2008 12:45 AM
bb4socal
Feb 11, 2006 06:22 PM
Ruben19
Jan 9, 2006 02:06 PM
boostagsr17
Jun 9, 2004 09:15 AM
