My new turbo, can someone identify this?
I bought this off of Jetli6969. Gonna put it on in a few days when my car gets back from Radley Acura. Damn thieves broke my ignition...
Its a T3/T4 Garrett (I think). No Garrett stamp on it anywhere. Exhaust has .48 stamped into it (on the inside).
Not sure about anything else! Looks like a very quick spooling turbo.
Re: My new turbo, can someone identify this? (BG Boost)
that looks like a t3t4b.. I have the same exact compressor housing.. so i'm pretty sure its the same ..
Re: My new turbo, can someone identify this? (92HB_HB)
6 blade/6 splitter compressor blade = T04E
7 blade/7 splitter compressor blade = T04B
Check the major and minor diameters of the compressor blade
[Modified by Dee, 7:14 PM 4/10/2002]
Re: My new turbo, can someone identify this? (int3gra)
So your saying if its double 6 its T04b and if its double 7 blades its t04e?
The Inline pro manifold did not come with it. I bought that seperately. And polished that bizotch by hand.
[Modified by BG Boost, 4:42 PM 4/10/2002]
if you polished your manifold with a wire wheel and not aluminum oxide sand paper, your manifold will rust! Take it to a metal treater and have them do a 300 series passivation in nitric acid at 140 degrees for half an hour.
Re: My new turbo, can someone identify this? (rtype11)
that thing has a "stainless steel" stamp on it..
rtype11 are u saying he polished the protective coat off.??
It has 6 double blades. But looks a LOT smaller then the one I had before which was a t3/t4e...
Anyone else?
Anyone else?
the only way to know for sure is to measure the major and minor diameters of the compressor blade!
major = largest diameter (compressor exducer)
minor = smallest diameter (compressor inducer)
Remove the compressor housing (six 12mm bolts and and three clamp sets), pull the housing off and then measure the two diameters of the blade with a micrometer (or caliper and ruler).
HTH...
HTH...
theEGkid
09-22-2005 10:44 AM
