CRX Resistor box
Old Apr 8, 2002 | 10:00 AM
turboteg96's Avatar
Default CRX Resistor box
Hey peeps, I pulled a resistor box from a late 80's CRX and I noticed that the wiring is not quite straight forward. There are 6 wires coming from the ECU and 5 wires comming from the resistor box. I have pics I am going to see if I can get some web hosting. Does anyone know the wiring skematics.
Thanks,
Ian
Old Apr 8, 2002 | 09:20 PM
b18c1-ek's Avatar
Default Re: CRX Resistor box (turboteg96)
This should give you a good idea. It is from a ClubSi member
http://www.hondata.com/cgi-bin/yabb/...num=1012601012
Old Apr 9, 2002 | 06:49 AM
Geovannie's Avatar
Default Re: CRX Resistor box (b18c1-ek)
Just out of curiousity, what happens when you put DSM injectors on your cars without a resistor box?
Old Apr 9, 2002 | 06:57 AM
Speed PHreak's Avatar
Default Re: CRX Resistor box (Geovannie)
Worst case......you toast your ECU
Old Apr 9, 2002 | 07:18 AM
turboteg96's Avatar
Default Re: CRX Resistor box (Speed PHreak)
The resistor box used is different from the one I picked up. Can anyone web host for me so that I could put up some pics. I tried image station but they never got back with to me.
Old Apr 9, 2002 | 08:16 AM
sgT's Avatar
sgT
there shold be 4 wires going to the injectors which are yellow/black stripe.
you should have 1 wire going into the resistor box(most likely yellow) and 4
coming out(should be red). You cut the 4 yellow wires to the injectors, connect
them to the 1 wire going into the box, then connect the other 4 wires to the
yellow/black wires on the injectors.
Old Apr 9, 2002 | 11:38 AM
turboteg96's Avatar
Default Re: CRX Resistor box (sgT)
Thanks, that makes sense.
siguy2k
Aug 21, 2012 09:46 PM
cristegra09
May 21, 2009 07:08 PM
BoostBoi
Nov 13, 2004 11:50 PM
lilxvtecxpwr
Apr 12, 2004 05:36 AM
Nextelbuddy
Dec 5, 2003 10:13 AM
