Just finished my wet kit install, god help me.....
I'm just a little nervous about the kit. Everything was ready to go yesterday, but I just filled the bottle today for the first time. I'm going downstairs as we speak for the final inspection of all my connections and then it's verdict time. Pray for me...
Re: Just finished my wet kit install, god help me..... (Bryson)
THE SQUEEZE!!!! Hit that $h!t Good luck bro, and have fun, once you hit it once and it doesn't blow up you will be on it all the time, better buy a spare bottle!
Re: Just finished my wet kit install, god help me..... (smackdown-lude)
Just got back. I tried the 25 shot first for a couple of seconds at a time. Then I pulled over checked the plugs (brand spankin new 1 step colder NGK's). They had black deposits so it's running rich--on the safe side. Then I popped in the 50 shot jets. Huge difference from the twenty five. I felt a nicccce surge. The rpms came up quick. Then when I was going to try the 75 shot, and ARRRRGGHH!!!! I couldn't find the 42 jet for the N20....FUUUUUUUUGGGG!! I'm gonna have to visit my local speed shop. You're right, I did want to keep squeezing.
[Modified by sando112, 10:11 PM 4/8/2002]
Re: Just finished my wet kit install, god help me..... (sando112)
hahahah, welcome to the darkside man .
haev fun , but play safe , it does get addicting /
and let your car cool down between runs.
Re: Just finished my wet kit install, god help me..... (GSRwBOOST)
if you have the nos kit with the ruby jets.. get the ruby jets.. dont get the normal brass looking ones.. they are not for use with thatkit and arent cinsistent at all
get an aftermarket ignition whit 75 shot and up you will less retard so more hp
retard exaust by 2 or 3 deg and fell the diff
enjoy
enjoy
Re: Just finished my wet kit install, god help me..... (mikvtec)
Well, I found the jet combo for the 75 shot. I tried it and it's definitely nasty! Only thing is that when I floor it my egine seems to not be able to "catch up" with the power. For example, I was driving on a long empty stretch of highway and floored it around 4k and it hit right away. When I tried at an rpm lower than that it seems to bog on me? It also seems to happen between shifts. I speed shifted like usual but as soon as I pop the clutch from 2 to 3 or 3 to 4 there is like a delay. My engine rpms drop and then, bam!!--the shot kicks in. My psi was about 1000 and I properly purged....what gives?
