water lines for turbo
Old Apr 9, 2002 | 11:57 AM
Brian_92GSR's Avatar
New User
Default water lines for turbo
What are some common places to get and return water for a turbo on a b-series (b17a)? I've got a new oil cooler installed - could the lines going to the built in oil cooler be bypassed to this instead? I believe both inlet and outlet on the turbo are 3/8" pipe thread.
Old Apr 9, 2002 | 12:08 PM
rtype11's Avatar
Default Re: water lines for turbo (Brian_92GSR)
hydraulic and pneumatic industrial supply house, they can make hose in any size with any fitting you need.
Old Apr 9, 2002 | 12:10 PM
JM Performance's Avatar
Default Re: water lines for turbo (rtype11)
i think hes asking where on the car...
Old Apr 9, 2002 | 12:14 PM
rtype11's Avatar
Default Re: water lines for turbo (00SilverLS)
then I still dont understand what he wants....does he want to run oil to the water cooled CHRA ??? or does he want to run an external water pump for the water cooled section?? then still go to a hydraulic supply house for an electric water pump and hoses. I do not suggest using engine coolant for the turbo.
[Modified by rtype11, 4:17 PM 4/9/2002]
Old Apr 9, 2002 | 12:51 PM
New User
I am asking where to get water to send to the water-cooled portion of the bearing housing. Would I be better off taking it from the stock oil cooler or the TB?
Old Apr 9, 2002 | 12:55 PM
turbopanda's Avatar
actually, i'd like to know about this too as my IHI RHF5 ballbearing turbo also has two holes on it for water cooling, yet i'm using the turbo without the water lines connected at the moment (people telling me its not really that necessary.. (?!?!)) Some pictures would be nice too
Old Apr 9, 2002 | 05:42 PM
New User
Default Re: water lines for turbo (nathan's boosted civic)
I would highly recommend using the hooking the water lines up, especially if they are already there. Having a water cooled bearing section will keep the oil from reaching the temperatures that it can coke up at.
Old Apr 9, 2002 | 06:38 PM
SilverLudeSi's Avatar
New User
Default Re: water lines for turbo (94hondahybrid)
I am hooking up some water lines for my turbo right now actually. I will put up some pics in an hour or two.
Old Apr 9, 2002 | 07:21 PM
New User
Default Re: water lines for turbo (SilverLudeSi)
Ok, I just used cheap lines from auto zone - we'll see if they hold up around the turbo. I just ran a line from the thermostat housing to the turbo, and then a line from the turbo to the throttle body. I didn't feel like bypassing the throttle body, so coolant just flows like this thermostat --> turbo --> throttle body. This is in a prelude but I don't think it matters that much. If anyone sees a problem with this set-up, please let me know.
Lines for the turbo are the newest looking ones.
bob102386
Sep 16, 2021 07:36 PM
endlessdv
Jan 1, 2006 10:15 PM
dryhopsux13
Sep 29, 2004 05:39 AM
asianspeed
Jan 28, 2003 04:30 PM
