Part # for LS rod & main bearings
Do each of the colors have their own part # ? If so I need the numbers of each if someone has them!
I wish sites like http://www.acuraautomotiveparts.net/ would list the part# on the page after you search...
Re: Part # for LS rod & main bearings (dustin)
yeah, each color has its own part # and each main(upper and lower) has their
own part as well. I have them written down somewhere..... question is... where
Re: Part # for LS rod & main bearings (88CRXHybrid)
brown and green
i need to measure though, cause I'm using eagle rods and I dunno what size they are. People tell me size 1, size 2, size 3 and "they are all different" heh.
Re: Part # for LS rod & main bearings (sgT)
Threads like this don't make me feel certain they are 3s:
https://honda-tech.com/zerothread?id=156613
Wel, i will tell you that with EVERY set of eagle rods i;ve used a #3 got me exactly
where I needed to be on the first try.
Hmm, i'm lazy so I'll just buy bearings like they are 3s and then I'll plastigauge them... if they are wrong well oh well hehe
I've dial-bore gauged alot of Eagle rods: not one freaking set measured the same...everywhere from a thou over the factory parameters to a thou under. We make it a habit to resize them right out of the box. On a lighter note, most sets are at least uniform to each other. Also, remember that buying a color only guarantees that you will get that grade, or the one above/below it...we also buy a bulk of bearings and measure and recatagorize them keeping stats on what to expect of a given grade keeping in mind that there are two different manufacturers, also (big $ in Honda bearings for inventory: d, b, and h series rods, mains-uppers/lowers...sucks to do things right). Don't worry if it takes two different colors to get the right clearance, either: up to 3 tenths difference in halves' thickness is fine.
Re: Part # for LS rod & main bearings (Del...'luded)
Hmm I have access to a dial bore gauge.. what size should I be looking for so I can at least /guess/ to purchase the right bearings?
Here are your part numbers bum...
Main Upper: Brown = 13323-PR3-004
Green = 13324-PR3-004
Main Lower: Bronw = 13343-PR3-004
Green = 13344-PR3-004
Rod Bearings: Brown = 13213-PR4-A02
Green = 13214-PR4-A02
I gave you both greeen and brown for both. Let me know if you need some help
JK
[Modified by Blown90hatcH, 4:53 PM 4/13/2002]
JK
icon_race_eg
05-23-2005 09:37 AM
waxbunny
10-14-2004 06:12 PM
