honda iat and coolant temp with speed pro?
o.k. my car is running timming is locked in, car idles rock solid at 1200 rpm, I cant get my coolant temp or air temp to read correct, my speed pro unit was setup for gm sensors. Any options, I figured I could just compare my coolant to my autometer gauge and adapt but what about my intake air temp?Any suggestions?want it to be right am going to dyno thursday, Jason
Re: honda iat and coolant temp with speed pro? (littlebluecrx)
to get the right reading you must use the gm sensors. i found that the honda IAT is about 10 degrees too hot. realistically its no big deal i know a lot of people who run this way. but since your going thru the trouble why not just weld a fitting on to your ic pipe somewhere to fit the gm IAT? and tap the major coolant port to fit the gm sensor?
NovaKnowledgeNow
07-26-2013 11:12 PM
