Plugs
Old Apr 9, 2002 | 06:04 PM
SlowB16's Avatar
Default Plugs
I did a search for this but nobody had this question. I got the NGK plugs (with the -11 at the end I dont remember the exact number) and they are gapped at .044 out of the box. I said I heard you need a .030-.032 for stock ignition, but he looked in his little book, and it said .044 recommended for a stock b16....So will the .044 gap be ok with my stock ignition? I am FI BTW
Old Apr 9, 2002 | 06:06 PM
FIxALPHA's Avatar
Default Re: Plugs (SlowB16)
Ive been using NGK part number 2756 (BKR6E 11) and gaped them to .025. Never had a problem and it's off the shelf at a local car parts store.
I forgot to add...Im using stock ignition except for the Taylor wires.
[Modified by FIxALPHA, 3:07 AM 4/10/2002]
Old Apr 9, 2002 | 06:16 PM
SlowB16's Avatar
Default Re: Plugs (FIxALPHA)
Isnt that a really small gap?? I dont know anything about gaps and plugs so enlighten me
Old Apr 9, 2002 | 06:28 PM
SlowB16's Avatar
Do you need a smaller gap because of the boost or something?
Old Apr 9, 2002 | 06:54 PM
SlowB16's Avatar
Anyone??
Old Apr 9, 2002 | 07:43 PM
FIxALPHA's Avatar
If you are using a stock ignition, you might not get enough spark. By decreasing the gap you have a better chance of igniting.
I had the gap over .030 and the car hesitated a bit. Changing the gap on the plugs made a difference.
Old Apr 9, 2002 | 07:54 PM
93LSivic's Avatar
Anyone??
Ok here is some GREAT info you can read up on. I found it very useful
http://www.ngksparkplugs.com/techinfo/spark_plugs/
Old Apr 9, 2002 | 10:15 PM
SlowB16's Avatar
So I should lower the gap to .030? Correct.....I just dont understand why the recommended is .040 and you guys are saying .030. Can someone clerify
BTW I read that NGK info page and I didnt find an answer to my question directly, but thanks for posting that!!
[Modified by SlowB16, 7:34 AM 4/10/2002]
Old Apr 10, 2002 | 12:06 AM
shadowdawn's Avatar
I have 2 step colder NGK plugs gapped at .30 with timing shot down to about 12 (safety reasons, but I can up it closer to stock now, just havent gotten around to it)
Old Apr 10, 2002 | 12:31 AM
b18cTurbo's Avatar
Default Re: Plugs (shadowdawn)
im using bosh fr6dcx gap to 28 whit msd ignition , boosting 16 psi
if i gap them to 30 i have misfire
Old Apr 10, 2002 | 04:06 AM
RGAZ's Avatar
New User
OK, lets do this.
Stock applications, use stock gap of 0.44" on 6 series plugs.
FI applications without MSD ignition, use 0.35" on 6 series plugs or 0.40" on 7 series plugs for boost under 8psi.
FI applications with MSD ignition can add 0.05" to the above gaps.
FI applications above 8 psi and under 12psi without MSD should only run 7 series plugs and 0.35" or smaller gaps.
FI applications with MSD igntion (8-12 psi) can run 0.05" wider gap.
After 12 psi on stock combustion chamber, you have to try combinations of colder plugs with MSD box and different gaps. The applications get really tricky at that point.
Randy
BTW-I use MSD as a generic term for ignition amplifier. You could run Crane, Jacobs, whoever.
Old Apr 10, 2002 | 04:39 AM
MiraiZ's Avatar
Default Re: Plugs (RGAZ)
how bout 7 series?
Old Apr 10, 2002 | 09:15 AM
SlowB16's Avatar
Default Re: Plugs (MiraiZ)
I am at 5 lbs and I have the 7 series plugs with a stock ignition. So where should they be gapped?
Shoot my fault you already said. Sorry about that
[Modified by SlowB16, 6:16 PM 4/10/2002]
hondaeg8
10
Feb 4, 2005 04:37 PM
Nikoli
Dec 1, 2004 01:15 PM
sp00led
Jun 10, 2004 08:45 PM
uneekcrx
Apr 9, 2002 05:13 AM
Dokta
Jan 23, 2002 05:39 PM
