Question: Experienced (engine)builders please
Old Apr 11, 2002 | 10:38 AM
rondigs's Avatar
Default Question: Experienced (engine)builders please
Recently I found a B17 crank(yeah, its a miracle). However, it has suffered a spun rod bearing(nooooh!). Is it possible to machine the crank and use a larger size bearing to compensate... Also, whats a good offer for a crank in this condition. Want to use it for LS/VTEC turbo. Thank-you-kindly-please
Old Apr 11, 2002 | 11:04 AM
sgT's Avatar
sgT
Default Re: Question: Experienced (engine)builders please (rondigs)
with factory bearings it really depends on how bad the damage is, but the
chances are that you wont be able to. Why would you want to destroke your
motor anyway? might as well get a b16a instead of an ls block.
Old Apr 11, 2002 | 11:26 AM
rondigs's Avatar
Default Re: Question: Experienced (sgT)
I asked for pictures of the crank-that would've helped. So you figure its a no-go. The guy told me he took it to a shop and they said it could be done. ...Just not sure.... Kinda iffy buying parts that have problems, but if it can be compensated for.. ?
As far as why I want one(B17crank)-better R&S for a fully built LS/VTEC turbo aiming at 9000RPM. Less torque(than the B18B crank), but more RPM
means staying in boost longe-hopefully safer.Don't think the B18B crank would enjoy 9000RPM...
Old Apr 11, 2002 | 11:32 AM
Suprdave's Avatar
Default Re: Question: Experienced (rondigs)
If you build it right, with a Girdle, etc...It'll survive 9k, Not Prob. Is this a Race Motor, or Street Motor? If its street, you should find a smaller turbo and shoot for 8k rpm...9k is alot and it squares the stressed on your parts, compared to 8k.
Suprdave
Old Apr 11, 2002 | 11:55 AM
blueciv69's Avatar
What are the stock bearing colors?
Old Apr 11, 2002 | 12:30 PM
88CRXHybrid's Avatar
Default Re: Question: Experienced (blueciv69)
he needs to have the crank and the block to depermine which color bearings he needs and he doesnt have the crank in his possession.
Old Apr 11, 2002 | 12:43 PM
rondigs's Avatar
Default Re: Question: Experienced (88CRXHybrid)
I guess you could say its a race motor in a street car. Everything is fully built...
I work at a drag strip so the car is going to make it down the track a couple times.
Anyhow, as far as compenstating the bearings... (+ or -)
Old Apr 11, 2002 | 12:54 PM
paulzy's Avatar
I had a couple pun bearings too....had to weld the journals and recut them to factory specs....
Old Apr 11, 2002 | 01:24 PM
sgT's Avatar
sgT
Default Re: Question: Experienced (94hondahybrid)
make sure the clearances are right
use only honda bearings
make sure your oil supply system is good
Old Apr 11, 2002 | 01:53 PM
rondigs's Avatar
How extensive was the welding and necessary work. Can any knowlegable machine shop perform the work.
Also, what is a good "offering" price for a crank in the previously mentioned condition??
Old Apr 11, 2002 | 01:56 PM
rondigs's Avatar
Would it be more benefical to just find(hopefully) a different crank....
sgT's Avatar
sgT
i cant tell you about welding work, because no place around here will weld just
one journal, only the whole crank.
I wouldnt pay more than 50 for a crank that spun a bearing.
Afterall, you are looking at a potential paperweight
Old Apr 11, 2002 | 02:18 PM
paulzy's Avatar
it cost me about 100 bucks to fizx it....yeah it was all the journals....it came back all shiny though
Old Apr 11, 2002 | 03:45 PM
rondigs's Avatar
Default Re: Question: Experienced (Slow_ass_4dr)
How long have you had it since the repair...Any signs of wear?
Old Apr 11, 2002 | 05:35 PM
sushibug's Avatar
dont know if this is helpful or not, but i had a friend who had a ls/vtec (it was a b18a bottom and a gsr head) and he banged on it for two plus years. took it over 8 grand a lot and what not and the motor is still in one piece but its leaking oil out of the distributor area. he had it put together by RiceWorks near San Diego.
titan101
Apr 3, 2013 08:52 AM
typer2k1
Dec 14, 2006 10:43 PM
RAS Motorsports
Mar 12, 2004 06:42 AM
