rin gap install problem
Old Sep 18, 2003 | 09:01 AM
crx1856's Avatar
Default rin gap install problem
when i installed my rings, the oil expander ring seems to be out of alignment when i put the oi rings on. i did get it to fit but it seems to be a snug and not move freely. all three rings seem to be snugly fit together. will this be a problem?
Old Sep 18, 2003 | 09:52 AM
Flamenco-T's Avatar
Default Re: rin gap install problem (crx1856)
one thing, when you filed the ring to gap it make sure to sand down the edges of the vertical part where it meets up on the other end. What happen is you have some sharp edges and it get stuck in the ringland grrove. Fiel the rings and sand down the sharp edges where the vertical part is.
Am I confusing ? lol
stan
Old Sep 18, 2003 | 10:02 AM
earl's Avatar
Default Re: rin gap install problem (Flamenco-T)
Stan, I think he is talking about the OIL ring...get back to selling that equipment
Don't file those oil rings...
Install the expander first, make sure the ends are not overlapping but just butting together with the ends pointing down. Install one of the rails. Make sure it still feels flexible and the expander has not overlapped itself on it's own. If it feels good, install the second rail.
Once installed, you should be able to squeeze it and kind of feel it compressing a little. You should also be able to move the whole assembly around the piston.
Remember it's the rails that scrape the oil from the walls, the expander just keeps them aligned. No oil control value.
Old Sep 18, 2003 | 10:06 AM
earl's Avatar
Default Re: rin gap install problem (earl)
Of course you are right about deburring those upper rings at the spot that you filed them. They have to be free also, as you post
Old Sep 18, 2003 | 10:30 AM
crx1856's Avatar
i didn't file the oil rings at all. the oil expander ring seems to be a tight fit at one part as if it is not completly flat. i can move all three rings together around the piston but it dosen't move freely seperatly. the middle expander ring seems to be snug between the two. the top oil ring didn't want to go in at first but it did go in.
Old Sep 18, 2003 | 10:44 AM
earl's Avatar
It sounds ok, hard to tell without being there. As long as it compresses slightly when you squeeze it, probably ok. Be sure the gaps of the three oil rings do not lineup over each other. They should be staggered.
Old Sep 18, 2003 | 12:29 PM
crx1856's Avatar
thanks earl. glad your here to help. whenever i got a ?, i search your name and most of the time i find awnsers......thanks...
Old Sep 18, 2003 | 01:27 PM
Mikes01GSR's Avatar
That's why I ordered my pistons from him!!
Old Sep 18, 2003 | 02:22 PM
Flamenco-T's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by earl &raquo;</TD></TR><TR><TD CLASS="quote">Of course you are right about deburring those upper rings at the spot that you filed them. They have to be free also, as you post</TD></TR></TABLE>
who do you think taught me about that at midnight in your garage ?
stan
1990_integra_DA9
Jul 21, 2008 06:22 AM
NSTY Z33
Apr 1, 2007 09:32 PM
wade
Jun 24, 2004 01:46 PM
crx1856
Sep 18, 2003 02:34 AM
