compression test problems, please help
Old Sep 19, 2003 | 04:49 PM
cornhusker's Avatar
Default compression test problems, please help
first, i was doing a compression test on my gsr and got a solid 120,120,120,120. they are all exactly the same, but it seems a low. any suggestions?
second, i was using the deep reach adapter on the end of the compression tester. then in the last cylinder and when i unscrewed the compression tester, the deep reach adapter was stuck in the cylinder. i tried multiple times to get it out. any suggestions on how to get it out? please help, thanks.
Old Sep 19, 2003 | 06:03 PM
cornhusker's Avatar
Default Re: compression test problems, please help (cornhusker)
anyone? please help! i cant be the only one that this has happened to?
Old Sep 19, 2003 | 09:10 PM
Double121's Avatar
That happened to me once. I had a pair of LOOONG needle nose pliers and managed to get it out. On the compression, did you crank the motor enough times to build up enough pressure?
Old Sep 19, 2003 | 09:48 PM
cornhusker's Avatar
Default Re: compression test problems, please help (Double121)
thanks for the advice, i will try that in the morning. btw, did you just use the pliers and untwist the adapter? if not, what did you do? thanks again.
Old Sep 20, 2003 | 03:11 PM
cornhusker's Avatar
i used some loctite and it did the trick. also, re-did the compression test with the engine warm and i got 190,190,200,200. so compression looks good across the board.
but, i noticed that i vacuum seems a little low (15inHG at idle), anyone have any ideas what the problem might be? thanks.
Old Sep 20, 2003 | 03:24 PM
TurboJesse
Guest
Posts: n/a
I did a test a few days ago...when the engine was cold, real cold, like hasn't run in 6 months and got 90,90,90,90 across the board. Once i get some coolant in im gonna let it run for awhile and see what it does. It starts fine and idles nice, no smoking, etc. Im hoping those numbers are from it being cold or that my timing may be off.
Old Sep 21, 2003 | 06:25 AM
coupey's Avatar
call me dumb but where can you get compression testers? and how much do they run..
Old Sep 21, 2003 | 06:46 AM
B94Cast's Avatar
Default Re: (nine nine si)
You can get compression testers at Napa, Autozone, PepBoys, etc.. They are fairly inexpensive, running anywhere from $25 to $70 depending on the make etc.
Old Sep 21, 2003 | 07:02 AM
coupey's Avatar
they wont let you rent them or anything will they?
So krazieY
Jul 25, 2009 09:57 PM
88 civic
Apr 5, 2009 03:21 PM
92vxjdm
Aug 15, 2008 05:05 AM
self_made
Jun 19, 2005 12:36 PM
