HELP!!! i need the advice of experienced engine builders...ring gap question..
Old Sep 18, 2003 | 11:50 AM
TheSwift1's Avatar
Default HELP!!! i need the advice of experienced engine builders...ring gap question..
OK, i just finished gapping my piston rings..i started with the second rings just becuase that was the set i grabbed first...they are JE .20 over pistons, according to JE specs for forced induction, i should have a ring gap of about 0.015", right?
well, here is my ring end gap specs when i measured with a feeler gauge:
Cylinder 1: 0.016"
Cylinder 2: 0.015"
Cylinder 3: 0.016"
Cylinder 4: 0.017"
Did i kill the rings? i was afraid i gapped them a little too much..will this affect oil comsumption? remember, that these are the SECOND rings, not the top ones...
BTW, the setup will be a B16 head/GS-R bottom end, supercharged JRSC 10psi, with NOS in the plans later on down the line...
Old Sep 18, 2003 | 11:53 AM
v-attack's Avatar
From: First in Flight, Type Rs of East Coast, NC, FL
Quick question what did you use to square the rings in the bore? (You are supposed to use a piston or a ring setting tool, and put them 1" down in there respectable bore)
Old Sep 18, 2003 | 11:56 AM
TheSwift1's Avatar
Default Re: (v-attack)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by v-attack &raquo;</TD></TR><TR><TD CLASS="quote">Quick question what did you use to square the rings in the bore? (You are supposed to use a piston or a ring setting tool, and put them 1" down in there respectable bore)</TD></TR></TABLE>
i set the pistons 1" from the bottom of the bore...use a piston to push the rings down and square it off...that's what's recommended by everyone...
Old Sep 18, 2003 | 12:14 PM
boostaholic's Avatar
Default Re: (TheSwift1)
that's fine, you're between .005" and .006" per inch of bore.
Old Sep 18, 2003 | 01:59 PM
TheSwift1's Avatar
Default Re: (boostaholic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostaholic &raquo;</TD></TR><TR><TD CLASS="quote">that's fine, you're between .005" and .006" per inch of bore.</TD></TR></TABLE>
so i should be OK? anyone else's input?
Old Sep 18, 2003 | 02:10 PM
boosted hybrid's Avatar
You seem to be numerically within the tolerance level.
1320london
Engine Machining & Assembly
Sep 17, 2016 12:00 PM
Paegelow
May 22, 2010 08:10 AM
turbodohcsi
Jan 1, 2005 10:22 AM
Sport_Injected
Oct 20, 2004 02:54 PM
filetofit
Sep 24, 2002 04:03 PM
