When can't you re-build a block?
Old Sep 20, 2003 | 06:18 AM
ScottEK's Avatar
Default When can't you re-build a block?
I want to build my engine this winter for high boost. I was originally going to pull my block (B16A) and send it out for sleeving. But now a new opportunity came up, my friend just blew up his GSR swap running N/A. His car was running like crap, the valves were making a lot of noise, he continued to drive it and it blew about a week later.
This is what he told me he found, pile of metal that looks to be intake valves in the plenium and throttle body. Exhaust valve shot down through a piston, and two cracks in the sleeves. If I could get this engine for under $100 would it be worth it? In these situations does the crank usually survive?
Old Sep 20, 2003 | 06:22 AM
boosted hybrid's Avatar
Default Re: When can't you re-build a block? (beta13)
The head sounds shot. The shortblock will still be good for sleeving if there arent any holes through the sides of the block. The crank should be fine, just check the crank journals for scarring. Run your finger nail over the journal, if you can feel scrathes you'll most likely need a new crank.
Old Sep 20, 2003 | 06:24 AM
ScottEK's Avatar
Default Re: When can't you re-build a block? (boosted hybrid)
Sorry I forgot to mention I'd be using my B16 Head and ARP head studs (they wont ) if they can transfer over, would it be worth getting his cams, sounds like the valves were flying everywhere though.
Old Sep 20, 2003 | 06:28 AM
The b16a can transfer over to the gsr block. The OEM cams are pretty bulletproof, just check if they are still straight.
Old Sep 20, 2003 | 08:55 AM
ahobbs's Avatar
HELLO,GOOD MORNIN'
You can use that bottom end, as long as theres not a actual hole in the block
Old Sep 20, 2003 | 12:15 PM
AlLMoToRvOtEr's Avatar
Buy the block and just get it sleeved and if the crank is messed up IM me I have another GSR crank just sitting I will sell to you............................
OMG THE GOGGLES
Jul 14, 2006 09:59 PM
wantboost
Welding / Fabrication
48
May 23, 2006 03:03 PM
1991civicsi
Mar 28, 2006 07:02 AM
streetsweeper
Jan 5, 2005 04:59 AM
