Advanced wideband tuning question.
Old Sep 19, 2003 | 08:28 AM
PHiZ's Avatar
Default Advanced wideband tuning question.
Pretentious title? sorry...
Anyways, just got my wideband in. It has the ability to feed a narrowband output back to the ecu.
I will be eventually, after appropriate research, and test-bedding my cars, tuning other peoples cars. At which point it would be more convenient for me to remove their O2 sensor, and put my wideband in, and feed a narrowband via a x-over harness to their ecu.
Basically I'm saving the hassle of welding a secondary o2 bung/plug.
Now, any opinions on how the car will run on the tune, after I take my wideband->narrowband setup out, and replace it with the factory O2 sensor?
Thanks in advance guys.
-PHiZ
Old Sep 19, 2003 | 09:45 AM
racinskittle's Avatar
Default Re: Advanced wideband tuning question. (PHiZ)
I was wondering that same thing. I am planning on doing that as well
Old Sep 19, 2003 | 10:00 AM
keebler65's Avatar
i used the techedge kit which has the same NBout feature as yours does. i've kept the system in the car ever since i installed my forced induction setup. (actually i drove around with it NA for awhile because i was doing everything i could to prep the car to save time later). anyways, i decided to keep the wideband in the car because i like the re-assurance of being able to see my a/f all of the time, just in case one of the variables changed in my setup without me knowing. it works perfect and i would recommend this setup.
Old Sep 19, 2003 | 10:41 AM
R6Elmo's Avatar
Default Re: Advanced wideband tuning question. (keebler65)
what phiz is talking about is actually tuning other peoples cars, not permanantly installing it in his.
Phiz...I dont' think going back to the stock 02 sensor will change anything. it's a narrowband output made only to tune for best fuel efficiency.
Albeit, the narrowband output 0-1v from the wideband is going to be 100x more accurate than what the stock 02 sensor is goign to give the ecu. I wouldn't worry about it.
Danny
Old Sep 19, 2003 | 11:26 AM
legendboy's Avatar
Default Re: Advanced wideband tuning question. (R6Elmo)
what engine management are you running?
Old Sep 19, 2003 | 11:38 AM
PHiZ's Avatar
Default Re: Advanced wideband tuning question. (legendboy)
ScrapinSI coined the phrase, and I love it. "NonData"
-PHiZ
BoldFart16
Engine Management and Tuning
12
Mar 12, 2011 06:09 AM
everythingwentblack
Nov 4, 2009 08:15 AM
k9n
Jun 9, 2006 02:58 PM
opto_isolator
Mar 27, 2004 05:37 PM
Westsideboy
Apr 20, 2003 07:46 PM
