HOSTED! dyno inside 56k beware!!
Old Sep 19, 2003 | 06:39 PM
graphic's Avatar
Default HOSTED! dyno inside 56k beware!!
98 prelude w/ f-max kit
at 5 psi intercooled
0 retard and tuned the mf2 a little
i can't figure out why i am making such shitty numbers...i checked timing,exhuast blockage, leaks, and even did a compression check...
i am missing like 30whp
and notice my power starts to fall off kind of early
Modified by graphic at 4:17 AM 9/20/2003
http://www.geocities.com/stickupman2000/
Modified by graphic at 4:33 AM 9/20/2003
Modified by graphic at 4:34 AM 9/20/2003
Old Sep 19, 2003 | 08:07 PM
FredoSP's Avatar
Default Re: HOSTED! dyno inside 56k beware!! (graphic)
hmm what were ur compression #'s .. u do a leakdown test?
whats ur fuel mgt like? I can bet its NOT hondata
Old Sep 19, 2003 | 08:11 PM
lazerus's Avatar
Default Re: HOSTED! dyno inside 56k beware!! (FredoSP)
uhm, hello lean!
Old Sep 19, 2003 | 08:21 PM
PureTeg420's Avatar
Default Re: HOSTED! dyno inside 56k beware!! (lazerus)
from 5700-7400rpms you are running way too lean
Old Sep 19, 2003 | 08:28 PM
meanteg's Avatar
New User
Default Re: HOSTED! dyno inside 56k beware!! (PureTeg420)
2.0 to 4.6 ? what does these numbers mean, in the a/f graph ?
Old Sep 19, 2003 | 09:33 PM
graphic's Avatar
Default Re: HOSTED! dyno inside 56k beware!! (meanteg)
compression # were as follows:
cyl 1 187
cyl 2 190
cyl 3 185
cyl 4 192
fuel management was erl mf2 w/ 2 additional injectors
the run before those two a/f was between 12.2-12.7 from like 4700 to redline...
still the same shitty numbers..
ignition timing at idle is 15 deg BTDC.
Old Sep 19, 2003 | 09:53 PM
turbologist's Avatar
What size turbo is this?
Old Sep 19, 2003 | 10:13 PM
MAX HARDCORE's Avatar
Default Re: HOSTED! dyno inside 56k beware!! (Turbologist)
well if your running a p13 ecu w/ vafc or hack for get about about it. p13's are the worst ecu's for boost.. i tried for months i broke down and got hondata.
Old Sep 19, 2003 | 10:17 PM
graphic's Avatar
Default Re: HOSTED! dyno inside 56k beware!! (MAX HARDCORE)
turbo is a to4b/t3 and i am running a stock 98 prelude ecu ...fuel managment is via...2 additional injectors ran by erl mf2
Old Sep 20, 2003 | 04:32 AM
GreddySi99's Avatar
your car is going to blow up if you dont fix that air fuel!!! dump that POS MF2 and get a hondata or some kind of engine management
Old Sep 20, 2003 | 05:04 AM
meanteg's Avatar
New User
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by meanteg &raquo;</TD></TR><TR><TD CLASS="quote">2.0 to 4.6 ? what does these numbers mean, in the a/f graph ? </TD></TR></TABLE>
Oh, that must be WB02 voltage ...
Old Sep 20, 2003 | 10:03 AM
gritsak's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by graphic &raquo;</TD></TR><TR><TD CLASS="quote">compression # were as follows:
cyl 1 187
cyl 2 190
cyl 3 185
cyl 4 192
. </TD></TR></TABLE>
not for long when your running that lean up top...boooooom
Old Sep 20, 2003 | 12:48 PM
lazerus's Avatar
Default Re: HOSTED! dyno inside 56k beware!! (gritsak)
oh, if you still cant figure out why you are making shitty numbers.. before you do any more trying to figure outting, fix your air fuel ratios, your motor will not take boost with those air fuel ratios!
TylerC161
Apr 11, 2008 10:20 AM
LSVTEC 91 Civic
18
Nov 10, 2005 06:59 PM
JDMTYPER
28
Oct 18, 2004 12:32 PM
graphic
Sep 20, 2003 02:04 AM
FSTASNTZ
Aug 26, 2001 11:42 AM
