what injectors to use for 500whp??
Re: (GRTechnologies)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GRTechnologies »</TD></TR><TR><TD CLASS="quote">a 720cc inj should be fine but the biger the better in you can control them</TD></TR></TABLE>
Nah, you'll run out of room on 720 @ around 460whp
Re: what injectors to use for 500whp?? (BodyKits NW)
From what i've found, the above are about right. 350whp on 550's and 450whp on 720's. If you want over 500, i'd go with as close to 1000's as you can find. No need to put yourself on the limit of your injector.
Re: what injectors to use for 500whp?? (porsche997)
I did 520whp on precision 1000's set at 45psi base. I don't know what the duty cycle was on that pass, but i made 575 on another at 90%.
Re: what injectors to use for 500whp?? (simple4012)
is an external fuel pump a must for larger injectors?
can you run a walbro 255 fuel pump, stock lines, and 1000cc injectors?
