Intercooler piping...
Old Sep 18, 2003 | 01:49 PM
NyQuiL's Avatar
Default Intercooler piping...
i recently bought a used spearco intercooler off a honda-tech member that measures around 29x8x3. The only thing im having trouble with figureing what type of intercooler piping im gona need to run. This is all for a integra coupe b18b, using a lovefab sst manifold and sc61. Would anyknow know what bends i should get and where i could get them? I was originally consering burns stainless but that seemed pretty expensive. I was considering purchasing piping from accordinlgy done's oscommerce store. Also where could i purchase the clamps and hoses to connect them all? and a flange for a hks ssq bov?
http://www.accordinglydone.com...id=85
Old Sep 18, 2003 | 01:54 PM
quikB18B's Avatar
Default Re: Intercooler piping... (NyQuiL)
Heres my setup
Jc whitney piping $78 shipped
Silicone hoses(black) http://www.atpturbo.com $6 a piece!!
T-bolt turbo clamps-b-day present from gsrsol, $3.79 a piece http://www.vecco.net
Hope that helps
Old Sep 18, 2003 | 03:53 PM
Ben Huynh's Avatar
If you need a pre-fab piping kit will BOV flange, clamps, and couplers, let me know.
Old Sep 18, 2003 | 04:12 PM
superfuji57's Avatar
Default Re: Intercooler piping... (ben@importparts.com)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ben@importparts.com &raquo;</TD></TR><TR><TD CLASS="quote">If you need a pre-fab piping kit will BOV flange, clamps, and couplers, let me know.</TD></TR></TABLE>
Do you have one to fit a Integra gsr w/inlinepro manifold?
Old Sep 18, 2003 | 11:38 PM
Ben Huynh's Avatar
Default Re: Intercooler piping... (superfuji57)
Yea we do. The kit comes with mandrel-bent chrome-plated piping with BOV flange of your choice, all couplers, and all clamps.
Old Sep 18, 2003 | 11:57 PM
V-SPEC 1's Avatar
Ben, I may need i/c piping for my 95 hatch hybrid civic, do you have something like that?
Vic
Old Sep 19, 2003 | 12:21 AM
Ben Huynh's Avatar
Default Re: Intercooler piping... (boostedb20vtec)
Of course. You have an PM.
Old Sep 19, 2003 | 04:30 AM
M.A.R.C.'s Avatar
Default Re: Intercooler piping... (quikB18B)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by quikB18B &raquo;</TD></TR><TR><TD CLASS="quote">Heres my setup
thanks for the tips
Hope that helps
Old Sep 19, 2003 | 08:50 AM
NyQuiL's Avatar
Default Re: Intercooler piping... (CivicRyda2k)
i got alot of good info from quickb18b but i wanted to hear some other peoples opinion on what setup this intercooler piping would take. When mounted, my turbo's inlet for the intercooler piping is going to face the front of the car, what kind of sharp bend will i need for this? heres how it will mount
(Please use imagination for what it will look like on car )
if i rotate it the other way the inlet would face the block, so that options pretty much a negative. (again, use of imagination would help )
Old Sep 19, 2003 | 09:21 AM
TurbodCX's Avatar
You do know you can reclock the compressor side, so that it doesnt point in towards the block right??
HTH
Brian
Old Sep 19, 2003 | 10:39 AM
NyQuiL's Avatar
Default Re: Intercooler piping... (TurbodCX)
never tried "re-clocking" or anything like that, what would it involve and would anything need to be rebalanced or anything of that sort.
Old Sep 19, 2003 | 11:01 AM
BROOD's Avatar
No, just loosen the compressor housing bolts enough so you can rotate the compressor outlet to the desired location. No rebalnce needed. I just would not remove the housing all together though, it is not nessesary.
You can also do the same for the center housing (to better locate the drain to vertical location) by loosening the turbine housing bolts and turning the center housing. Keep in mind that you should first orientate the center housing then the compressor outlet. Otherwise you have to move the compressor twice.
Garrett sends torque specs for these bolts in the turbo box. Good luck
Old Sep 19, 2003 | 11:07 AM
bOOsTiNSoHcVtEc's Avatar
Default Re: Intercooler piping... (SLPR)
hey ben.. do u have the kit fer a 95 civic ex?
Old Sep 19, 2003 | 11:17 AM
Ben Huynh's Avatar
Default Re: Intercooler piping... (bOOsTiNSoHcVtEc)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bOOsTiNSoHcVtEc &raquo;</TD></TR><TR><TD CLASS="quote">hey ben.. do u have the kit fer a 95 civic ex?</TD></TR></TABLE>
Yea we do. You have a PM.
Actually if you guys can get at least 5 orders together, we can start a group buy at a group buy price.
Old Sep 19, 2003 | 11:19 AM
quikB18B's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NyQuiL &raquo;</TD></TR><TR><TD CLASS="quote">never tried "re-clocking" or anything like that, what would it involve and would anything need to be rebalanced or anything of that sort.</TD></TR></TABLE>
Oh no wonder your having problems, yeah like he said just loosen the bolts, you dont have to take them out just loosen enough so that it rotates (there like 6 i think)(12mm) in center section and rotate it until desired location and retighten. Just make sure your oil drain flange is still in a good position
Old Sep 21, 2003 | 04:51 PM
NyQuiL's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SLPR &raquo;</TD></TR><TR><TD CLASS="quote">
Garrett sends torque specs for these bolts in the turbo box. Good luck </TD></TR></TABLE>
i didnt get anything in the box, just the turbo. it was from art.
chriskey0829
Nov 30, 2006 04:45 AM
wrx'n you
Sep 2, 2005 12:30 PM
Soon_2b_evil
Oct 12, 2003 03:04 PM
ebp 99 si
Sep 15, 2003 02:37 PM
BlackB18CTeg
Jun 28, 2003 11:21 PM
