ok to only get a boost gauge instead of boost/vac
Old Sep 18, 2003 | 07:41 AM
JDM_EH2's Avatar
Default ok to only get a boost gauge instead of boost/vac
im gonna purchase a set of autometer c2 electrical gauges (boost, egt, oil pressure) and i was wondering if its ok to get the 0-30 psi boost gauge istead of getting the vac/boost gauge...i like the uniform look where the needles all start at the same angle...thanks!
Old Sep 18, 2003 | 07:53 AM
GSRwBOOST's Avatar
Default Re: ok to only get a boost gauge instead of boost/vac (BoostedCivic94)
sure why not...
only difference is you just wont see a low vacume or high vacume reading to indicate any problems...
When my ringlands went out, my vacume changed a little....
but your probably safe in doing just the positive side... (boost)
Old Sep 18, 2003 | 08:06 AM
Nextelbuddy's Avatar
Default Re: ok to only get a boost gauge instead of boost/vac (GSRwBOOST)
what is a good vacuum reading when your at idle? my gauge reads at 20 vac at adle is that bad? i heard 15 was the proper reading
Old Sep 18, 2003 | 08:47 AM
Alstare's Avatar
Default Re: ok to only get a boost gauge instead of boost/vac (nextelbuddy)
I sit at 22@idle on my autometer 30/20 boost gauge....
Old Sep 18, 2003 | 08:48 AM
Poop111444's Avatar
20 is perfect. that is what mine is.
Old Sep 18, 2003 | 09:10 AM
XDEep's Avatar
Default Re: ok to only get a boost gauge instead of boost/vac (Poop111444)
ya there are a a couple diagnostic procedures you can do with the vacuum readings. they are described in the chiltons (yuck) manual from autozone. definitely get the vacuum gauge.
FRernesto
Aug 29, 2007 07:01 AM
turbonitrousgsr
Oct 6, 2003 06:54 AM
b18tdelsol
May 18, 2002 11:46 AM
Aeka GSR
Mar 26, 2002 02:12 PM
